Value of frictional force applied
In summary, the mass of A is 5kg and the mass of B is 10kg. If the acceleration of A is 2m/s^2 which is smaller than acceleration of B, where A is placed on top of B, then the value of frictional force applied by B on A is:A) 50N.
Priyadarshini
191
The mass of A is 5kg and the mass of B is 10kg. If the acceleration of A is 2m/s^2 which is smaller than acceleration of B, where A is placed on top of B, then the value of frictional force applied by B on A is:
A) 50N. B) 20N. C) 10N. D) None of these
a(max)=meu*g
frictional force=meu*normal force
[/B]
normal force= 5*10=50N
meu= 2/10 = 1/5
frictional force= 10N
But I had to assume that 2m/s^2 was the maximum acceleration. Can I do that? Because otherwise there are too many unknowns.
Thanks in advance!
Where did you get the normal force from?
sorry, I forgot to mention the masses. The mass of A is 5kg and B is 10kg
You don't need to assume that 2 is the max acceleration, they've asked for the frictional force in this situation, not for the maximum frictional force that can exist, so you don't need to worry about that.
But how would I do it if I don't assume that it is maximum? Because the a=meu*g formula is only for maximum a. So if I don't assume it to be the maximum how would I go about solving it?
You are assuming you need to find mu, but you don't.
Forget B, forget friction. A mass m is undergoing a (horizontal) acceleration a in consequence of a net horizontal force F. What equation connects the three?
F=ma
Priyadarshini said:
F=ma
Right. So apply that.
In this case it doesn't matter if 2m/s^2 is the maximum acceleration or not
When two blocks are moving relative to each other,the friction between them is always the maximum (when they start their motion or are sliding w.r.t. respect to each other)
If they have a certain relative acceleration,the friction acting is kinetic and is always a constant force
are the two blocks on the ground?Does the ground possesses friction?
is it frictionless??
assuming the ground /surface offers friction is going to make the problem too cumbersome/hard to solve(2 equations,3 unknowns!)
I'll try to do it assuming the ground is frictionless!:)
and yeah no implicit assumptions
As I posted (#6 and #8), you do not need to think about B at all. You know the mass of A, you know its acceleration, and you want to know the force acting on it.
truly said,haruspex
it's friction which acts forward and provides the acceleration for A
and thus F=m*a=5*2=10 N is the magnitude of the frictional force!:)
I was just complicating things,wasn't I,for the OP?
My bad
1. What is the value of frictional force applied?
The value of frictional force applied is the amount of force that is exerted on an object due to friction. It is measured in units of Newtons (N).
2. How is the value of frictional force applied determined?
The value of frictional force applied can be determined by measuring the normal force and the coefficient of friction of the surfaces in contact. The formula for calculating frictional force is Ff = μN, where μ is the coefficient of friction and N is the normal force.
3. Can the value of frictional force applied be negative?
Yes, the value of frictional force applied can be negative if the direction of the applied force is opposite to the direction of motion. This is known as kinetic friction.
4. How does the value of frictional force applied affect motion?
The value of frictional force applied can affect motion by slowing down or stopping the motion of an object, or by causing an object to move in a different direction than the applied force.
5. What factors can affect the value of frictional force applied?
The value of frictional force applied can be affected by the type of surfaces in contact, the roughness of the surfaces, the normal force, and the speed of the object in motion.
