jakeus
- 1
Does the force of Friction acting on an object equal the applied force on an object if it is in constant motion?
Is that one of Newton's Law's? Which?
Thank you
Thank you
Friction is a force that resists the motion between two surfaces that are in contact with each other.
Newton's first law of motion, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
Friction is a force that opposes motion, so it can act as the external force that causes an object to come to a stop or change its velocity. In other words, friction can cause an object to follow Newton's first law of motion.
Static friction is the force that resists the motion of an object that is not yet moving, while kinetic friction is the force that resists the motion of an object that is already in motion.
Friction can be reduced by using lubricants, such as oil or grease, between two surfaces, or by using smoother surfaces. Additionally, reducing the force pushing the surfaces together can also decrease friction.
