Frictional force homework help
  1. Jun 24, 2008 #1
    A 20-kg block on a horizontal surface is attached to a light spring (force constant = 8.0 kN/m). The block is pulled 10 cm to the right from its equilibrium position and released from rest. When the block has moved 2.0 cm toward its equilibrium position, its kinetic energy is 13 J. How much work is done by the frictional force on the block as it moves the 2.0 cm?
    do I need a coefficient of friction to solve this?
  3. Jun 24, 2008 #2
    kreil
    You are told what the blocks kinetic energy is with friction, so if you solve for what it should be without friction then the difference is the work done by the frictional force...no coefficient of friction needed.
  4. Jun 24, 2008 #3
    ok, I get that but how would I find the velocity to get the kinetic energy?
    ke = 1/2 M*V^2
    or am I still not getting it?
  5. Jun 24, 2008 #4
    PhanthomJay
    You need to apply the total conservation of energy principle. Are you familiar with it?
  6. Jun 24, 2008 #5
    ummm.......no. I'm about to google it tho, but please explain.
  7. Jun 24, 2008 #6
    PhanthomJay
    In the absence of non conservative forces other than friction, you should discover that [tex]\Delta K + \Delta U + W_{friction}= 0[/tex]. Now you must apply it.
  8. Jun 25, 2008 #7
    I got it. I think it works out to be -1.4J
  9. Jun 25, 2008 #8
    PhanthomJay
    Looks right. Even your minus sign is correct. I slipped on mine, sorry, I should have said [tex] \Delta K + \Delta U - W_{friction} = 0[/tex]
