1. PF Contest - Win "Conquering the Physics GRE" book! Click Here to Enter
Frictional force
  1. Dec 13, 2011 #1
    A rotating disk of radius 2.0m (the mass on the disk, assume is negliable) with 4 points of mass each spaced 90 degrees apart from each other, each weighing 19kg. Each is position 0.2m from the axle.
    Inertia of the disk is 3.04 kg m^2
    Angular Speed is 310 rad/s
    Torque is initially at 0 Nm, as no force is acting upon it.
    A frictional force is then applied to the rim, of 94 N. How long does it take to come to a complete stop?
    2. Relevant equations
    I assume F x r = torque
    But after this, I'm not sure where to go.
    3. The attempt at a solution
    Not sure where to begin
  3. Dec 13, 2011 #2
    You've got the right idea in your 'relevant equations' section. You can calculate the torque using the information given. That's the first step you should try.
  4. Dec 13, 2011 #3
    Therefor torque = 94 N x 2.0 m = 188 N m.
    Will I need inertia for the next step?
  5. Dec 13, 2011 #4
    "Will I need inertia for the next step?"
    It's a rotating object that is being stopped. What does that tell you?
  6. Dec 13, 2011 #5
    This is correct.
