Homework Help: Frictionless inclined plane
  1. Jun 28, 2007 #1
    1 An object is pushed up a smooth incline of 30 degrees with a speed of 4m/s. In seconds, how long will it take before the object stops and reverses direction?
    Vf= Vo - at
    Vf= Vo - at
    0 = 4 - (9.8)t
    t = 0.41s
    I know this is wrong because the angle isn't accounted for, but I'm not sure where to use it. I'm not sure what the right answer is either.
    2 An object is placed on an incline of 30 degrees . The object is pushed up the incline at the initial speed vo=4m/s. How far does it travel before stopping and reversing direction?
    Vf= Vo - at
    Vf= Vo - at
    0 = 4 - (9.8)t
    t = 0.41s
    x= (Vxo)(t)
    x= (4)(0.41)
    x=1.6m
    For some reason, this gives me the right answer, but I again don't use the 30 degrees anywhere. What should I be doing?
  3. Jun 28, 2007 #2
    Doc Al
    Staff: Mentor
    This is incorrect. First find the actual acceleration by considering the component of gravity acting along the incline. (This will involve a bit of trig.)
    This is incorrect because the speed is not constant. You'd need the average speed to find the distance using this method.
    Amusingly, the two errors you made exactly cancel.
  4. Jun 28, 2007 #3
    ok, then to get acceleration, would I use:
    a = g sin theta
    a = 9.8 sin 30
    a = 4.9 m/s^2
    then to solve for time:
    Vf= Vo - at
    0 = 4 - (4.9)t
    t = 0.82 s
  5. Jun 28, 2007 #4
    Doc Al
    Staff: Mentor
    So far, so good.
  6. Jun 28, 2007 #5
    Question 1 is then answered.
    Question 2, if I need avg. speed:
    V avg = Vf + Vo / 2
    V avg = 0 + 4 / 2
    V avg = 2
    X = Xo + Vot + 1/2at^2
    X = 0 + (2)(0.82) +1/2(o)^2
    X = 1.64m
  7. Jun 28, 2007 #6
    Doc Al
    Staff: Mentor
    That's the correct average speed. To get the distance use [itex]V_{ave} = \Delta X / \Delta T[/itex].
    Using this equation is a perfectly fine way to solve for distance, but you need to do it right. Two problems: (1) Vo is the initial velocity, not average velocity; (2) What happened to the last term? ([itex]1/2at^2[/itex]) It's not zero!
  8. Jun 28, 2007 #7
    For Question 2 using the formula you gave, then
    Vavg = delta X/ delta t
    2 = delta X / 0.82
    delta X = 1.64m
    I got the same answer, but my original equation was all wrong.
    with correct numbers
    X = 0 + (4)(0.82) +1/2(4.9)^2
    X = 3.28 + 12.01
    X = 15.29m
    Which one is right?
  9. Jun 28, 2007 #8
    Doc Al
    Staff: Mentor
    Correct method = correct answer.
    Wrong values = wrong answer.
    The last term ([itex]1/2at^2[/itex]) is not correct. What is the acceleration? (Careful with signs--if up the incline is positive, then down the incline must be negative.) What is the time?
    This equation for uniformly accelerated motion will come up often, so be sure you get it straight.
  10. Jun 28, 2007 #9
    I've often had problems with these questions. When I put a value in for acceleration, my teacher always circles it and says there should be no acceleration when solving for distance X, so I get confused alot!
    I know I've got the right answer, but want to know how to correct this other equation.
    X = 0 + (4)(0.82) +1/2(4.9)(0.82)^2
    X = 3.28 - 1.64
    X = 1.64m !!
    THANKS !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  11. Jun 29, 2007 #10
    Chronos
    cosine theta of the inclination [in a gravitational field] would be worthy of consideration.
  12. Jun 29, 2007 #11
    Doc Al
    Staff: Mentor
    Not all motion is accelerated. For example, in projectile motion problems the acceleration only affects the vertical motion, not the horizontal. In such a problem there will be no acceleration when solving for horizontal (x-axis) distance.
    The only error that I see is having the wrong sign for the acceleration in the first line. The magnitude of the acceleration down the incline will be [itex]g \sin 30 = g/2 = 4.9[/itex], but the sign should be negative, since it acts down the incline.
  13. Jun 30, 2007 #12
    Chronos
    In a projectile problem, you have two forces - gravity and propulsion.
  14. Jun 30, 2007 #13
    Doc Al
    Staff: Mentor
    Once an object has been thrown or released, it becomes a projectile. Ignoring air resistance, the only force acting on it is gravity. (Once released, any propulsive force no longer acts.)
  15. Jul 1, 2007 #14
    Chronos
    Correction noted. Initial velocity is the proper terminology.
