Fröbenius method
  • Thread starter DevoBoy
I'm trying to solve the differential equation:
[tex]x^2y''+2xy'+(x^2-2)y=0[/tex]
using the Fröbenius method.
So I want a solution on the form
[tex]y=\sum_{n=0}^\infty a_{n}x^{n+s}[/tex]
After finding derivatives of y, inserting into my ODE, and after some rearranging:
[tex]\sum_{n=0}^\infty ((n+s)(n+s-1)+2(n+s)-2)a_{n}x^{n+s} + \sum_{n=2}^\infty a_{n-2}x^{n+s}[/tex]
Looking at n=0, assuming [tex]a_{0}[/tex] different from zero, I get two possible values for s:
[tex]s_{1}=1[/tex]
[tex]s_{2}=-2[/tex]
Both giving [tex]a_{1}=0[/tex]
Choosing s=1, I get
[tex]a_{n}=\frac{-a_{n-2}}{(n+s)(n+s-1)+2(n+s)-2}=\frac{-a_{n-2}}{n(n+3)}[/tex]
I know [tex]a_{n}=0[/tex] for odd n, so I'm interrested in finding [tex]a_{n}[/tex] for even n, expressed by [tex]a_{0}[/tex]. Best thing I can come up with is
[tex]a_{n}=\sum_{n=2,4,6,..}^\infty \frac{3(-1)^{n/2}a_{0}}{(n+1)!(n+3)}[/tex]
which seems overly complicated given the simple recursive formula. Any ideas?
Second problem; I want to find another linear independent solution, but not quite sure where to start given my ugly expression for [tex]a_{n}[/tex].
Answers and Replies
Your equation is almost certainly some kind of Bessel equation. You should seek solutions in terms of Bessel functions.
Edit:
In fact, it is a Bessel function. Specifically, a spherical Bessel function apparently. There are also general solutions on the page. Remember that in order to obtain the correct expansion, you must use the boundary values of the problem.
HallsofIvy
41,847
969
[tex]s_{1}=1[/tex]
[tex]s_{2}=-2[/tex]
Choosing s=1, I get
I don't see how you could get a sum like that. Starting with
[tex]a_n= \frac{-a_{n-2}}{n(n+3)}[/tex]
You get, for the first few terms, [itex]a_2= -a_0/(2(5))[/itex], [itex]a_4= a_0/(2(5)(4)(7))[/itex], [itex]a_6= -a_0/(2(4)(5)(7)(6)(9)[/itex]
Okay, it looks like
[tex]a_{2n}= \frac{3(-1)^n a_0}{(2n)!(2(n+1)+ 1)}[/tex]
but there is no sum!
Okay, it looks like
You're absolutely right. My mistake.
After reading up on Bessel functions (thanks ObsessiveMathsFreak!!), I've rewritten my recursion formula as
[tex]a_{2n}=\frac{(-1)^{n}a_{0}\Gamma(1+3/2)}{2^{2n}n!\Gamma(n+5/2)}[/tex]
which seems to expand beautifully.
Related Threads on Fröbenius method
  • Last Post
11K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
11K
