jangheej
- 19
it's widely known that a body (whether it's a particle or fluid) moves from a hot region to a cold region.
But while doing an experiment, I observed otherwise.
The experiment is plunging a hot wire into a beaker filled with water with powder floating on the surface. When I put the hot wire, the powder did not immediately move away from the wire, but first moved toward the wire and then bounced off.
Why is it that the particles are first attracted to the wire?
Could it be related to a change in surface tension?
If so, specifically how does the surface tension change?
And how can I quantitatively measure the effect of the plunging in the experiment so that I can only consider the effect of heat energy transfer?
