Fubini's theorem help
  1. Jan 11, 2006 #1
    Hi all,
    I don't fully understand the usage of Fubini's theorem.
    Let's say I have to compute the area of
    [tex]
    \Omega \subset \mathbb{R}^2\mbox{ , }\Omega\mbox{ is bounded with }y = x^2\mbox{ and }y = x + 2
    [/tex]
    [tex]
    \mbox{area(\Omega)} = \iint_{\Omega} 1\ dx\ dy
    [/tex]
    When I draw the situation, I easily find leftmost and rightmost point of this area, which have x-coordinates -1 and 2, respectively.
    Well, Fubini tells us that the integral above can be evaluated as (in this case) two nested one-dimensional integrals. But I have problems with the lower and upper bounds.
    The outer integral is clear, it will be
    [tex]
    \int_{-1}^{2} ...
    [/tex]
    But I'm not sure with the inner one. I know the bounds can't be 0 and 4, because that would give me the area of the whole rectangle.
    So, right solution is this:
    [tex]
    \iint_{\Omega} 1\ dx\ dy = \int_{-1}^{2}\left( \int_{x^2}^{x+2} 1\ dy\right)\ dx = ... = \frac{9}{2}
    [/tex]
    I don't fully get it...why are the bounds of the inner integral [itex]x^2[/itex] and [itex]x+2[/itex]? I know those are the bounding curves, but in Fubini's theorem there is just
    [tex]
    \int_{a_1}^{b_1} \left( \int_{a_2}^{b_2} ...
    [/tex]
    Which I can't connect with the bounds in my example.
    And other question - why is it
    [tex]
    \int_{x^2}^{x+2}
    [/tex]
    and not
    [tex]
    \int_{x+2}^{x^2}\mbox{ ?}
    [/tex]
    Is it because on the interval [itex](-1, 2)[/itex] the function [itex]x+2[/itex] is greater than [itex]x^2[/itex]?
    Thank you very much for clarifying this...
  3. Jan 11, 2006 #2
    Galileo
    You integrate from x^2 to x+2, because x^2 is the lower bound and x+2 the upper bound, as you can easily see from a drawing.
    A way to visualize it is this. What does the inner integral mean? In this case, it is the length of the vertical line between the bounding curves as a function of x. Right? It's simply [itex](x+2)-x^2[/itex] in this case.
    A little more generally, you can use double integrals like [itex]\int_a^b \int_{g(x)}^{h(x)} f(x,y)dydx[/itex] to find the volume of the graph under f(x,y) in which case the inner integral will be the area under the graph obtained by intersecting the graph of f(x,y) with a vertical plane parallel to the yz-plane (or xz-plane, depending on the variable) as a function of x. The inner integral is just a function of x, and it's an area like a standard integral. Then you integrate that along y to get the total volume. If you can visualize that procedure I`m sure you see why the bounds are what they are.
  4. Jan 11, 2006 #3
    Thank you Galileo! I think it's more clear to me now. This was very easy problem, I hope I will understand the three-dimensional as well :)
  5. Jan 11, 2006 #4
    benorin
    I'm just curious: does Fubini's Theorem extend to the case of multiple integrals taken w.r.t. different measures?
    Like, say the Lebesgue and counting measures?
