• Support PF! Buy your school textbooks, materials and every day products Here!
Fuction and Graph
  • Thread starter Harmony
1. Homework Statement
The function f is defined as
f(x)=3x^5-10x^3+1
1) Determine the maximum and minimum points, as well the point of inflection of the graph f.
2. Homework Equations
All the differentiation equation.
3. The Attempt at a Solution
I found the maximum point and minimum point, but I had some trouble with the inflection point.
So....
f''(x)=60x^3-60x^2
f''(x)=0,
60x^3-60x^2=0
x=0, x=1
f'''(0)=0
Hence the only inflection point is (1,-6)
But the answer given is (0,1),(1,-6)and (-1,8). Is the answer correct?
Answers and Replies
123
Not sure this should be in this topic as it is calculus not precalculus.
Have another look at your differentiation, in particular check the term -60x^2 in your expression for f''(x).
3,761
f''(x)=60x^3-60x^2
This second derivative is wrong. Calculate it again.
Your approach is correct though.
marlon
HallsofIvy
41,734
893
f(x)=3x^5-10x^3+1
So....
f''(x)=60x^3-60x^2
f''(x)=0,
60x^3-60x^2=0
x=0, x=1
f'''(0)=0
f"(x)= 60x3- 60x= 60x(x2- 1)= 0
for x= 0, 1, and -1.
One definition of "inflection point" is that the second derivative changes sign there. Yes, it is true that since f '''(0)= 0, the second derivative might NOT change signs there. For example, if f ''= x2, then while f''(0)= 0, f'' does not change signs there. But f'''(0)= 0 does not mean it CAN'T change signs there. For example, if f ''= x3, then, again, f'''(x)= 3x2 so f'''(0)= 0 but x3 does change signs there.
In this particular case, f''(1/2)= 60/8- 120< 0 while f''(-1/2)= -60/8+120> 0 so f'' does change signs at 0.
Related Threads for: Fuction and Graph
  • Last Post
  • Last Post
  • Last Post
