Full Hamiltonians
  • Thread starter OmniReader
Wikipedia distinguishes between the full "Molecular Hamiltonian" and the "Coulomb Hamiltonian" with which you solve the Schrodinger equation here: http://en.wikipedia.org/wiki/Molecular_Hamiltonian.
how is full molecular Hamiltonian written for a H nucleus and electron or H2 molecule?
Answers and Replies
DrClaude
Mentor
7,616
4,038
You usually do not use the full molecular Hamiltonian, but add relativistic corrections, such as spin-orbit coupling, to the Coulomb Hamiltonian.
Actually, I'm not sure that would be such a thing as the "full" molecular Hamiltonian. You would use the Dirac instead of the Scrhödinger equation to get all relativistic effects to be taken into account.
If you see the Hamiltonian specified on page 3 here: http://www.phys.ubbcluj.ro/~vchis/cursuri/cspm/course2.pdf
What would I add to that to make it as exact as we know how to make it? That is, if relativistic corrections are reasonably easy to make. Spin-orbit coupling is a purely relativistic effect?
DrClaude
Mentor
7,616
4,038
Let me start by answering
ISpin-orbit coupling is a purely relativistic effect?
No, I was a bit clumsy in my phrasing. In constructing a relativistic theory for the electron, which Dirac did, you end up needing spin to construct an equation that is Lorentz-invarient. But spin is not in itself a relativistic phenomenon, but an instrinsic property of the electron.
If you start from the Dirac equation for one electron and assume that relativistic effects are small, you can obtain a series expansion in terms of ##v/c## that you can use as corrective terms (or perturbation) in the Hamiltonian for the hydrogen atom. Spin-orbit coupling is one of those terms. Actually, you get (assuming a fixed nucleus)
\hat{H} = m_e c^2 + \frac{\hat{P}^2}{2m_e} + V(R) - \frac{\hat{P}^4}{8 m_e^3 c^2} + \frac{1}{2 m_e^2 c^2} \frac{1}{R} \frac{d V(R)}{dR} \hat{L} \cdot \hat{S} + \frac{\hbar^2}{8 m_e^2 c^2} \Delta V(R) + \ldots
The terms are in order: (1) mass energy of the electron; (2) kinetic energy of the electron; (3) Coulomb potential; (4) relativistic correction to the momentum; (5) spin-orbit coupling; (6) Darwin term (due to the Compton wavelength of the electron).
Note that the interaction between the spin of the electron and the spin of the nucleus is not included here, but can be added as an additional term.
For molecules (and for atoms with more than one electron), things are more complicated. You have additional terms due to spin-spin interactions between electrons.
Related Threads on Full Hamiltonians
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
