madmike159
The first one I got from a book by New Scientist.
For the first experiment you need a microwave oven, a chocolate bar and a ruler.
You can use these to find the speed of light ([tex]c\ =\ 2.99792458\ \times\ 10^{8}\ m\ s^{-1}[/tex]). Take the rotating tray out your microwave oven and place the chocolate bare inside and turn it on. You should start to see hot spots appear on the chocolate bar, this is because the microwaves don't heat evenly if it isn't rotating. Take the chocolate bar out the microwave oven and use your ruler to measure the distance between 2 hot spots, then look in your microwave oven user manual to find the frequency of the wave. Finally use the equation v=f[tex]\lambda[/tex] and you should have a value close to the speed of light. (If not you can still eat the chocolate).
The second experiment is more dangerous. You need a metal fuel can, a fire or BBQ, a pole to pick up the fuel can and what ever you feel you need to keep your self safe (gloves, goggles etc). You put some water in the can but not enough to make it so heavy you can't lift it easily, you then put it on the fire with the cap off/open. When the water boils lift the can off with the pole, then close the cap (using gloves) and stand well back. As the can cools down the pressure in the can drops and the weight of the atmosphere with begin to crush the can.
(This experiment can be quite dangerous so do it sensibly, don't try it inside)
