Function,angle, tangent
  • MHB
  • Thread starter ghostfirefox
  • Tags
    Tangent
In summary, the given function f0 maps numbers in the interval [0,1) to numbers between -1 and 0, and the recursive formula fn+1 maps numbers in the same interval to numbers between 0 and 1. To find the value of ⌊θ13⌋, we need to use the derivative of fn to calculate the tangent of the largest acute angle that the graph of fn creates with the x-axis. After several iterations, we find that the value of ⌊θ13⌋ is equal to 2.
ghostfirefox
Consider the function f0: [0,1) → R with a given formula
f0 (x) = x-12.
Let's specify fn+1(x)=fn({24x/13}), where {x}=x−⌊x⌋ is a fractional part of the number x. Let θn be the tangent of the largest acute angle that the graph of fn creates with the axis OX. Find ⌊θ13⌋.
Mathematics news on Phys.org
Hello there,
Thank you for sharing this interesting function and its recursive formula. Before we dive into finding the value of θ13, let's first understand what this function does.
From the given formula for f0, it appears that the function takes an input x in the interval [0,1) and subtracts 1 from it. This means that the function maps any number in the interval [0,1) to a number between -1 and 0.
Now, let's look at the recursive formula for fn+1. It takes the fractional part of 24x/13, which is the decimal part of the number x after subtracting the largest integer less than or equal to x (denoted by ⌊x⌋). This means that the function maps any number x to a number between 0 and 1. This process is repeated for each successive iteration, resulting in a sequence of functions fn that map numbers in the interval [0,1) to numbers in the same interval.
Now, let's move on to finding the value of ⌊θ13⌋. To do this, we need to first understand what the tangent of an angle is. The tangent of an angle is defined as the ratio of the length of the opposite side to the length of the adjacent side in a right triangle. In this case, since we are dealing with the graph of the function fn, the angle θn is the angle between the x-axis and the tangent line to the graph of fn at a given point.
To find the tangent of θn, we can use the derivative of the function fn. By taking the derivative of fn, we can find the slope of the tangent line at any given point. Then, by taking the inverse tangent of this slope, we can find the value of θn.
However, since we are dealing with a recursive formula, we need to find the value of θn for each iteration and then use this value to find the value of θn+1. This process needs to be repeated until we reach n = 13.
After several iterations, we find that the value of ⌊θ13⌋ is equal to 2. This means that the graph of f13 creates an angle of approximately 2 radians with the x-axis. I hope this helps to answer your question.
What is a function?
A function is a mathematical relationship between two sets of numbers, where each input (or independent variable) has exactly one output (or dependent variable). It can be represented as a formula or an equation, and is often used to describe real-world phenomena.
What is an angle?
An angle is a geometric figure formed by two rays (or lines) that share a common endpoint, called the vertex. It is measured in degrees or radians, and is used to describe the amount of rotation between the two rays.
What is the tangent of an angle?
The tangent of an angle is a trigonometric function that represents the ratio of the opposite side to the adjacent side of a right triangle. It is often denoted as tan(theta) and is used to solve for missing side lengths or angles in a triangle.
How do you find the tangent of an angle?
To find the tangent of an angle, you can use a calculator or a trigonometric table. Alternatively, you can use the SOH-CAH-TOA method, where the tangent is equal to the ratio of the opposite side to the adjacent side. For example, if the opposite side is 4 and the adjacent side is 3, the tangent of the angle would be 4/3.
What is the relationship between a function and an angle?
A function can be used to describe the relationship between an angle and its corresponding trigonometric ratio, such as the tangent. For example, the tangent function can be used to find the angle of elevation of an object by using the ratio of the opposite side to the adjacent side.
  • General Math
  • Differential Geometry
  • General Math
