Function of units
  • Thread starter quietrain
quietrain
655
ok, lets say i am plotting a graph of Energy VS voltage
so my units will be Joules VS Volt
so my gradient will be Joules per voltage
but what if i plot ENergy VS square root of VOltage?
will it become Joules VS VOLT1/2
so gradient = Joules per Volt1/2 ?
my lecturer once said you cannot take a function of anything with units. but what if the equation itself has units?
like E=mc2. if i plot E against c2, will the units become J VS m2s-2
Answers and Replies
tiny-tim
25,838
255
… my lecturer once said you cannot take a function of anything with units. but what if the equation itself has units?
Hi quietrain! :smile:
I think (s)he was talking about functions like cosx, ex, and logx …
the "x" in those cases must be dimensionless.
But (s)he's not talking about powers, like x2 or √x.
Studiot
5,441
I don't see why.
For instance distance, x is measured in metres.
Now supposing I consider a standing wave.
The displacement, y is also measured in metres and is a function of x such that
y = cos(x).
Why don't you just ask your teacher what was meant? Perhaps you misheard or only heard part of it.
tiny-tim
25,838
255
Hi Studiot! :smile:
… The displacement, y is also measured in metres and is a function of x such that
y = cos(x).
No, y is the amplitude times a cosine.
The amplitude is a length, the cosine is just a dimensionless number.
And it isn't cosx where x is a length, it's cos(x/L) where L/2π is the wavelength, and x/L is just a dimensionless number. :wink:
Studiot
5,441
Thank you
Redbelly98
Staff Emeritus
Insights Author
12,143
165
Put another way, a calculation result should not depend on the units you are using.
"cos(x)" would be different for x measured in meters vs. x measured in feet. But it's okay to have
cos[x / (1 m)]​
Then it doesn't matter whether you use (for example) x=0.500 m or equivalently x=1.64 feet, you still get cos(0.500)=0.878
quietrain
655
er. so what is the answer to my question in the first post? hehex...
the_house
134
There are no problems with any of your examples. You just misunderstood what the lecturer said (unless the lecturer was mistaken, but we'll assume that's not the case.)
Some functions make sense when the argument has units, and some would just be nonsense if you tried to put a dimensionful quantity as the argument. For example, x to any power can make perfect sense if x has units, but taking the cosine of a number with units makes no sense. For example, think about its Taylor series. You would be adding together terms that each have completely different dimensions, which is just total nonsense.
I think it is an important point, though. "cos(x)" would not just be interpreted differently if you put x in meters or feet---it's just nonsense either way. Sometimes people get lazy with notation (maybe there's really a (1 m^-1) in the argument that someone just didn't bother to write because it's understood) but it's good to keep this in mind.
quietrain
655
oh? so if i plot length VS 1/sqrt(VOLTAGE)
my units will be (m) VS (V-1/2)?
quietrain
655
i see.. thanks a lot!
tomkeus
77
Think about it this way:
Say you have cos and expand it around zero
[tex]\cos x=1-\frac{x^2}{2}+\frac{x^4}{24}-...[/tex]
If x is, say, in meters you would have to add meters and square meters which makes no sense.
quietrain
655
ah i see.. so its ok to square a length but not ok to take cosine of a length
so squaring length gives m2 as units.
thanks!
quietrain
655
dreads... another problem,...
ok, to find the relation of magnetic field B at the center of a loop to radius of that loop, B = Rx
so in this case , if i want to find x, i have to take ln on both sides, giving me lnB = xlnR , doing this will allow me to plot a graph of lnB vs lnR to get x as the gradient of a straight line graph
but the problem is taking ln of B and R. B and R has units of T and m... so can i do so? if i can, then what will be my units of lnB and lnR?
or is there another way that i can manipulate the equation B = Rx so that i can plot a straight line graph? thanks
Oudeis Eimi
77
Choose a reference pair of values for [itex]B[/itex] and [itex]R[/itex], say [itex]B_0[/itex] and [itex]R_0[/itex], such that [itex]B_0=R_0^x[/itex].
[itex]
\begin{displayeqn}
\frac{B}{B_0}=\left(\frac{R}{R_0}\right)^x \Rightarrow \log\left(\frac{B}{B_0}\right)=x\log\left(\frac{R}{R_0}\right)
\end{displayeqn}
[/itex]
quietrain
655
ah i see thank you very much!
Suggested for: Function of units
  • Last Post
  • Last Post
  • Last Post
10K
