Function question with expression
In summary, the concept of an infinitely nested square root can be represented by a sequence of functions, where the limit of the sequence is the value of the nested square root. The value of the nested square root is independent of the initial choice for x, and immediate convergence occurs when x is equal to the value of the nested square root.
Icebreaker
[tex]f(x)=\sqrt{2x}[/tex]
[tex]x(f)=\sqrt{2f}[/tex]
Does this express:
[tex]\sqrt{2\sqrt{2\sqrt{...}}}[/tex]
Mathematics news on Phys.org
It doesn't express anything because you are using the same symbol, "x", to represent two different things. If [tex]f(x)= \sqrt{2x}[/tex], the x(f) could only mean the inverse function which is [tex]x(f) = \frac{f^2}{2}[/tex]
IF you had said [tex]f(x)= \sqrt{2x}[/tex] and
y(f)= [tex]\sqrt{2}[/tex], then you could say
y(x)= [tex]\sqrt{2\sqrt{2x}}[/tex].
If you have
[tex]f(x) = \sqrt{x}[/tex]
then
[tex]f(f(x)) = \sqrt{\sqrt{x}}[/tex],
and
[tex]f(f(f(x))) = \sqrt{\sqrt{\sqrt{x}}}[/tex]
etc.
Considering the function f as an operator, we can write the last expression above as, for example:
[tex]f^3 x = \sqrt{\sqrt{\sqrt{x}}}[/tex]
and, in general,
[tex]f^n = \sqrt{\sqrt{...}}[/tex]
where there are n square root signs.
perhaps he implied x(f) in the first equation
Wait, is it possible to have "x" in "f(x)" or "f" in "x(f)" to be the function instead of the variable? So the infinite fraction described in the first post can be written the same way?
Consider the function
[tex]f(x) = \sqrt{2x}[/tex] defined on the non-negative reals.
Then,
[tex]f_2(x) = \sqrt{2{\sqrt{2x}}[/tex]
(The reason I'm using the subscript rather than the exponent notation will become clear soon).
Then the nested square root thing can be defined by the recursion
[tex]f_1(x) = \sqrt{2x}[/tex]
[tex]f_{n+1}^2(x) = 2f_n(x)[/tex] ---(eqn 1)
where the exponent of 2 on the LHS signifies squaring.
The infinitely nested square root thing can be represented by
[tex]\sqrt{2\sqrt{2\sqrt{...}}} = \lim_{n \rightarrow \infty} f_n(x)[/tex]
At the limit, [tex]f_{n+1}(x) = f_n(x)[/tex]
so using the recursion in eqn 1,
[tex]f_n^2(x) = 2f_n(x)[/tex]
[tex]f_n(x)[f_n(x) - 2] = 0[/tex]
giving a trivial solution of [tex]f_n(x) = 0[/tex] for [tex]x = 0[/tex]
and a nontrivial solution [tex]f_n(x) = 2[/tex] for [tex]x > 0[/tex]
So [tex]\lim_{n \rightarrow \infty} f_n(x) = \sqrt{2\sqrt{2\sqrt{...}}} = 2[/tex] for [tex]x > 0[/tex]
For interest's sake, note that the actual value that you set for [itex]x[/itex] doesn't matter (as long as it's positive). The limit always converges to 2. The choice of value for [itex]x[/itex] only decides from which direction the nested functions converge to that limit. For [itex]x < 2[/itex], it's from the left, and for [itex]x > 2[/itex], it's from the right. For [itex]x = 2[/itex], convergence is immediate.
Interesting. Thanks everyone.
It's not true.The value DOES matter
[tex] \sqrt{2\sqrt{2\sqrt{2\sqrt{...}}}}=2 [/tex]
[tex] \sqrt{3\sqrt{3\sqrt{3\sqrt{...}}}}=3 [/tex]
Generally
[tex] \sqrt{k\sqrt{k\sqrt{k\sqrt{...}}}}=k ,k\geq 0[/tex]
Daniel.
Generally
Daniel.
Refresh yourself on how I defined the function. I took some care with that.
Okay,got it.You defined a sequence of functions.I don't see the relevance of "x",though.
[tex] f_{n}\left(k\right)=:\substack{\underbrace{\sqrt{k\sqrt{k\sqrt{...\sqrt{k}}}}}\\ \mbox{n times}} [/tex]
I thought that was your function for k=2.
Daniel.
Daniel.
The 'x' was to prove a point about how the limit is independent of the initial choice for x. And to illustrate that with the right choice of x (in this case, 2), you get immediate convergence to the same limit.
In your definition, I could say [tex]f(x) = \sqrt{kx}[/tex] and the limit is k. Immediate convergence occurs when x = k.
It's just a minor point I wanted to illustrate.
:wink:
What is a function?
A function is a block of code that can be called and executed multiple times in a program. It can take in parameters and return a value or perform a specific task.
What is an expression?
An expression is a combination of values, variables, operators, and function calls that evaluates to a single value. It can be a mathematical calculation, a string, or a boolean value.
How do functions and expressions relate to each other?
Functions often use expressions within their code to perform specific tasks or to return a value. Expressions can also be used as arguments when calling a function.
What is the syntax for writing a function with an expression?
The syntax for writing a function with an expression is:
function functionName(parameters) {
// code to be executed
return expression;
Can expressions be used as standalone code?
Yes, expressions can be used as standalone code. For example, a console.log(expression) statement will output the value of the expression to the console without the need for a function.
  • General Math
  • General Math
  • General Math
  • General Math
