Functional derivative of effective action
In summary: F(D(x,y))} \log D^{-1}_i(z,z) = \sum_i \operatorname{tr} \frac{1}{D_i(z,z)} \frac{\delta}{\delta F(D(x,y))} D_i(z,z), where the index i runs over the internal indices. Note that we used the fact that the trace of a matrix is equal to the sum of its eigenvalues, and since the logarithm of a matrix is the sum of the logarithms of its eigenvalues, we can write \operatorname{tr} \log D^{-1}_i(z,z) = \sum_j \log \lambda
Ravendark
1./2. Homework Statement
In my QFT lecture we were introduced to the 1PI effective action ##\Gamma[\varphi]## for a scalar theory (in Euclidean space-time). In one-loop approximation we've found [tex] \Gamma^{(\text{1-loop})}[\varphi] = S[\varphi] + \frac{1}{2} \operatorname{Tr} \log D^{-1}[/tex] where ##D^{-1} = \delta^2 S[\varphi] / \delta \varphi \delta \varphi## denotes the inverse classical propagator.
Now I'm asked to compute the derivative of ##\Gamma^{(\text{1-loop})}## with respect to ##D##. And this is is point where I got stuck.
We had the functional derivative in the exercises and we derived formulas like [tex]\frac{\delta}{\delta f(y)} f(x) = \delta(x-y) \; , \qquad \frac{\delta}{\delta f(y)} \int dx \, f(x)^n = n f(y)^{n-1} \quad (n \in \mathbb{N})\; .[/tex] Furthermore, I know that the functional derivative obeys the product and chain rule.
[/B]
Since the action does not depend on ##D##, I have: [tex] \frac{\delta}{\delta D(x,y)} \Gamma^{(\text{1-loop})}[\varphi] = \frac{1}{2} \frac{\delta}{\delta D(x,y)} \operatorname{Tr} \log D^{-1}[/tex] Now I'm not sure how do deal with the trace...I think it is meant in the functional sense, thus [tex]\frac{\delta}{\delta D(x,y)} \Gamma^{(\text{1-loop})}[\varphi] = \frac{1}{2} \frac{\delta}{\delta D(x,y)} \int d^4z \, \operatorname{tr} \log D^{-1}(z,z)[/tex] where the lowercase tr runs over internal indices (colour, flavour...). Now I have no idea how to proceed...there is this trace, a log and furthermore the inverse of ##D## instead ##D## itself. Can someone give me a hint, please?
Thank you for sharing your question regarding the computation of the derivative of the 1-loop effective action with respect to the inverse classical propagator. I understand that this can be a challenging task, but I will try my best to guide you through the process.
Firstly, as you correctly pointed out, the action does not depend on D, so we can focus on the term \frac{1}{2} \frac{\delta}{\delta D(x,y)} \operatorname{Tr} \log D^{-1}. To make things simpler, let's consider the functional derivative with respect to a general function F(D), instead of the specific point (x,y). This will allow us to write the final result in a more compact form.
Using the chain rule, we can write \frac{\delta}{\delta D(x,y)} \operatorname{Tr} \log D^{-1} = \frac{\delta}{\delta F(D(x,y))} \operatorname{Tr} \log D^{-1} \frac{\delta F(D(x,y))}{\delta D(x,y)}. Now, let's focus on the first term on the right-hand side. Using the properties of the functional derivative that you mentioned, we can write it as \frac{\delta}{\delta F(D(x,y))} \operatorname{Tr} \log D^{-1} = \frac{\delta}{\delta F(D(x,y))} \int d^4z \, \operatorname{tr} \log D^{-1}(z,z) = \int d^4z \, \frac{\delta}{\delta F(D(x,y))} \operatorname{tr} \log D^{-1}(z,z). Now, we can use the fact that the trace is a linear operation and split it into a sum of individual traces. This will allow us to use the functional derivative formula for a product, which you mentioned in your post.
So, we have \frac{\delta}{\delta F(D(x,y))} \operatorname{tr} \log D^{-1}(z,z) = \frac{\delta}{\delta F(D(x,y))} \sum_i \operatorname{tr} \log D^{-1}_i(z,z) = \sum_i \frac{\delta}{\delta F(D(x,y))} \operatorname{tr} \log D^{-1}_i(z,z)
FAQ: Functional derivative of effective action
What is the functional derivative of effective action?
The functional derivative of effective action is a mathematical tool used in theoretical physics and quantum field theory to calculate the variation of a functional with respect to its arguments. It is represented by the symbol δ/δφ, where φ is a field variable.
How is the functional derivative of effective action calculated?
The functional derivative of effective action is calculated by taking the limit of the ratio of the change in the functional over the change in the field variable, as the change in the field variable approaches zero. This can be represented mathematically as δ/δφ = lim(ΔS/Δφ).
What is the physical significance of the functional derivative of effective action?
The functional derivative of effective action allows for the calculation of important physical quantities, such as correlation functions, in quantum field theory. It also plays a key role in the study of renormalization and quantum effective actions.
What is the relationship between the functional derivative of effective action and the path integral?
The functional derivative of effective action can be derived from the path integral formulation of quantum field theory. It represents the functional derivative of the path integral with respect to a field variable, and is used to calculate expectation values of physical observables.
What are some applications of the functional derivative of effective action?
The functional derivative of effective action has many applications in theoretical physics, including the study of phase transitions, critical phenomena, and quantum field theory. It is also used in the calculation of renormalization group flows and in the development of effective field theories.
