• Support PF! Buy your school textbooks, materials and every day products Here!
Fundamental Frequency
Which of the following could be the fundamental freq. for a vibration that has an overtone freq. of 990 Hz?
a. 330
b. 660
c. 148
d. 1980
e. 1990
(All in Hz.)
The formula that I think you have to use is f_n = n*f_1, where f_1 is fud. freq.
Then, I thought
f_2 = 2*f_1, where f_2 is the overtone freq. (is these a correct assumption?)
but 990/2 is 495.
Could someone direct me to the correct path of getting the solution?
I'm confused over the definitions of overtone and fund. freq.
Thanks.
Answers and Replies
Gokul43201
Staff Emeritus
There's no reason to assume than n=2, so you just leave it as n.
So you have [itex]f_n = nf_1 [/itex]
Or [itex]f_1 = \frac {990}{n} [/itex]
Which of the choices satisfies this condition for some integer n ?
Can you say if [itex]f_1[/itex] will be greater than or less than 990 Hz, from this ? Does this rule out any choices ?
The alternative is simply to notice that [itex]f_n/f_1 = n [/itex], so try the remaining choices of [itex]f_1[/itex] to see which one gives you an integer ratio.
Is the answer A?
The fud freq. would be less than 990, would it not? That leaves A and B, and 990/3 is 330.
Gokul43201
Staff Emeritus
That's right.
Related Threads for: Fundamental Frequency
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
