- 3,309
- 694
I would like a reference for a purely algebraic proof of the fundamental theorem of algebra - or if you would like to supply a proof that would be even better.
Are you sure?This proof is (...) purely algebraic.
Here you are using the fact that every polynomial with real coefficients of odd degree has a real root. Either this follows from FTA* (because of FTA there are an odd number of roots, complex roots come in conjugate pairs, hence at least one root is real), or from the intermediate value theorem. Obviously the first argument is not allowed in a proof of the FTA, so you still have to use analysis.TMM said:then the fixed field of P is an odd extension of R, which must be real, and since complex roots come in pairs, it follows this extension is trivial.
Landau said:Are you sure?
*FTA = the fundamental theorem of algebra
Of course this is an analytic proof! The intermediate value ultimately rests on the completeness of R, which is almost by definition an analytic property. This is also what I already said:TMM said:It's a really trivial application of the IVT. Monic, odd polynomials are large and positive for large x and large and negative for small x, hence they cross the axis somewhere. I hardly consider this an analytic proof.
Then you reply saying you have a "purely algebraic proof", while you are doing exactly what I predicted. The point is, a purely algebraic proof does not exist, whether you call the result that you use from analysis trivial or not.Landau said:I don't think a purely algebraic proof is possible. The completeness of R or C has to come up somewhere, i.e. some analytic aspect has to be invoked, like the intermediate value theorem.
See here for several proofs.
Landau said:Of course this is an analytic proof! The intermediate value ultimately rests on the completeness of R, which is almost by definition an analytic property. This is also what I already said:
Question: does there exist a purely algebraic proof of FTA?TMM said:I suppose I also used numbers so it's a number theory proof. And I had to found it in ZF so it's a set theory proof. It might as well also be called a combinatorics proof since that's how Sylow's theorem is proven.
I understand that some proofs require more analysis. But the question was about a purely algebraic proof, not about an algebraic proof. Anyway, let us wait and see which proof in the wikipedia link (which includes your Artin proof) TS likes best.When asked for an analytic proof of the theorem, I would've supplied the complex analytic one in your link. I don't think the OP is a picky as you are.
Nope. The IVT is a theorem of, for example, real closed fields.Landau said:Of course this is an analytic proof! The intermediate value ultimately rests on the completeness of R,
That is irrelevant. We were talking about the IVT for the field R. And the IVT for the field R is equivalent to completeness of R. That's all I claimed.Hurkyl said:There exist real closed fields that are not complete, yet satisfy the polynomial IVT.
I am aware of this.In any case, "real closed field" is a buzzword for you to go searching; there are a variety of ways to characterize the notion. Being an ordered field, and satisfying the polynomial IVT is one of them.
I mixed your name up with the OP, and thought you wrote both posts, so that confused things a little.Landau said:Hyrkyl, I appreciate your input, but I think it is inappropriate to have a discussion about model theory in this thread. I am not trying to draw a hard, rigoruous line between 'analytic' and 'algebraic': as explained, 'analytic' in this context just means that the completeness of R is involved, that's all. So there is no problem, let alone an ill-posed problem.
The Fundamental Theorem of Algebra is a mathematical theorem that states that every non-constant polynomial equation with complex coefficients has at least one complex root.
The Fundamental Theorem of Algebra is important because it provides a fundamental understanding of complex numbers and their relationship with polynomial equations. It also has many practical applications in fields such as physics, engineering, and data analysis.
The proof of the Fundamental Theorem of Algebra is complex and relies on advanced mathematical concepts such as complex analysis and topology. It was first proven by mathematician Carl Friedrich Gauss in the early 19th century.
Yes, the Fundamental Theorem of Algebra only applies to complex numbers. This is because complex numbers are necessary to solve certain polynomial equations that do not have real solutions.
The Fundamental Theorem of Algebra has many applications in fields such as physics, engineering, and data analysis. It is used to solve problems involving polynomial equations, such as finding the roots of a polynomial function or determining the behavior of electrical circuits.
