Fundamental theorem of calculus
In summary, there are two theorems: the fundamental theorem of calculus and a theorem relating to the differentiability of a function defined by an integral. These theorems can be shown to imply each other through a few lines of manipulation, using the antiderivative of a continuous function. The mean value theorem can also be used to demonstrate this relationship.
roam
1,271
There are two theorems:
The fundamental theorem of calculus: [tex]\int_{a}^{b}F'(x) = F(b) - F(a)[/tex]
And the theorem that states if f is continious on [a,b]and g:[a,b]->R is defined by
g(x) = [tex]\int_{a}^{x}f(t) dt[/tex], then g is differentiable on (a,b) and;
g'(x) = [tex]\frac{d}{dx}(\int^{x}_{a}f(t)) = f(x)[/tex]
"There’s one question that asks if it is possible to readily show that each one implies the other, by a few lines of manipulation."
Does anyone know how to do that?
Let f be cts on [a,b], and let F(x) = [tex]\int f(x) dx[/tex] be called F, the antiderivative of f. Then
[tex]\int_{a}^{b}f(x) dx = F(b) - F(a)[/tex]
By theorem [tex]\frac{d}{dx}(\int^{x}_{a}f(t)) = f(x)[/tex], we know [tex]\int_{a}^{x}f(t) dt = F(b) - F(a)[/tex] & F(x) has the same derivative, f(x). Hence there will be a constant c such that [tex]\int_{a}^{x}f(t)dt = F(x)+c[/tex] When x = a, we get
F(a) + c = [tex]\int_{a}^{a}f(t)dt = 0[/tex] so c = -F(a)
Hence, [tex]\int_{a}^{x}f(t)dt [/tex] = F(x)-F(a)
When x = b this yields
[tex]\int_{a}^{b}f(t)dt = F(b)-F(a)[/tex]
I'm not sure if this really answers the question though.
do you know the mean value theorem?
A little, how can I use it to show that in those two theorems each one implies the other one?
What is the Fundamental Theorem of Calculus?
The Fundamental Theorem of Calculus is a theorem that connects the concepts of differentiation and integration. It states that if a function is continuous on a closed interval, then the derivative of the integral of that function is equal to the original function.
How is the Fundamental Theorem of Calculus useful?
The theorem allows for the evaluation of integrals without having to use the limit definition of integration. It also provides a way to find the area under a curve by using anti-derivatives.
What is the difference between the first and second parts of the Fundamental Theorem of Calculus?
The first part of the theorem states that the derivative of the integral of a function is equal to the original function. The second part states that the integral of the derivative of a function is equal to the original function, as long as the function is continuous on the interval of integration.
Can the Fundamental Theorem of Calculus be applied to all functions?
No, the function must be continuous on the interval of integration for the theorem to hold. If the function is not continuous, then the theorem may not be applicable.
Is there a real-world application of the Fundamental Theorem of Calculus?
Yes, the theorem has many applications in physics, engineering, and economics. It can be used to calculate the position, velocity, and acceleration of objects in motion, as well as to solve optimization problems in economics.
  • Calculus
  • Calculus
