How does the concept of fundamental velocity relate to parallel rates?
In summary, the conversation revolved around the concept of velocity as a parallel rate, with the distance/time formula being an expression of this rate. The idea of reversible numerators and denominators in parallel rates was also discussed, with examples such as meters per second and seconds per meter. The main issue of velocity was identified as the increase of one component with respect to the other, and two mechanisms were proposed for this differentiation: shrinking the distance unit or stretching the time unit. The conversation also touched on the concept of moving clocks and their relation to time dilation. The conversation ended with a theoretical physicist's quote about moving clocks and a discussion on the empirical evidence of moving clocks running faster.
Futobingoro
I hope you can follow my train of thought (I'm not being elitist here, I am open to the possibility that my post may be unintelligible)
1. Velocity is a parallel rate.
The distance/time formula with which we are familiar is an expression of the number of meters laid end to end alongside one second. For example, another parallel rate would be the number of traffic signs alongside a kilometer of roadway.
2. Parallel rates have reversible numerators and denominators.
1 meter per second is the same as 1 second per meter. Looking back at my example of the roadway, we can see that 4 signs per kilometer is the same as .25 kilometers per sign.
So the fundamental issue of velocity is how we address the inevitable increase of one component with respect to the other.
Imagine that an object's velocity increases from 1 m/s to 2 m/s.
All of a sudden there is twice as much distance alongside the same 1 second of time.
Was this accomplished by the squeezing of 2 meters into one second?
Or was it accomplished by the stretching of that second out to a distance of 2 meters?
No takers?
Perhaps I am not explaining it adequately.
Look at the figure below.
http://img378.imageshack.us/img378/3154/timecs0.jpg
Legend
Red = time
Black = distance
In the top figure, the velocity is 6 units per second. The bottom figure shows 3 units per second.
In terms of metrics, however, the distance units of the two velocities are different. With respect to a third measurement (pixels in this case) the time units are the same in length. The higher velocity of the upper figure was accomplished by shrinking the distance unit so that more could fit within one second.
There is an alternate version.
http://img418.imageshack.us/img418/6352/time2vj9.jpg
In this illustration, the distance units are standardized. The mechanism which differentiates between the velocities here is the number of distance units one second is 'stretched' to cover.
Which is the mechanism that distinguishes one velocity from another?
Or are they both correct?
I think I figured out the answer myself.
"Moving clocks run slow, moving meter sticks are shortened..."
Tim Halpin-Healy
Theoretical Physicist
Barnard College, Columbia University
Moving clocks run faster.
I deal with satellites and GPS systems. One of the major concerns is that the clocks on the satellites run faster than stationary ground clocks. The solution has been to program the satellite clocks to run slower. They still need to be re-synchronized periodically.
According to the IEEE "At an altitude of. 20 184 km, a satellite clock runs fast relative to a clock on the geoid at a rate of 45.7 µs per day."
Unfortunately you have to be a member to view the document.
I found this though. This should explain why moving clocks go faster.
http://tycho.usno.navy.mil/ptti/ptti2002/paper20.pdf
Moving clocks run slower according to that paper. The data for GPS that shows the clocks
running faster is a result of the gravitational red shift time dilation (faster) overshadowing
the velocity time dilation (slower).The satellites
at lower elevation is less redshifted for example and shows a slower
moving clock. Basically they assumed they could add the time dilation effects together.
Tim Halpin-Healy
Well, let's apply that explanation to a test experiment with
two or three or more cars racing from one stop light to the next.
One car has twice the velocity as the other. It's apparent the
kilometer distance between stop lights doesn't change during the race.
It's also apparent that the car traveling twice as fast doesn't
shrink to half the first car's size. So this should be enough to falsify
the part about moving sticks shortening. Now, if
the drivers were wearing stop watches, they could also time their
race. Afterwards they compare the stop watches, they would indeed
find the faster car to have recorded half the time as the slower car.
So empirically, it would seem like a change in velocity is better
viewed as a change in time rate- or real time dilation without space
contraction.
Another analogy would be like a movie. A 2 and a half hour reel of
film for example could be played at normal speed or at fast forward.
At all times , if matter is conserved, that reel of film is one length.
Played fast forwarded, it would finish playing earlier than at normal
speed. So again, time dilation is apparent but not length or space
contraction.
No, moving clocks run faster. "The results of the first flight test, shown in Figure 8, are representative of our results in general. The
aircraft flew for nearly 4 hours at an altitude of 11,000 m (35,000 ft) at an average speed of 790 km/h
(425 knots). Our analytical results suggest that the flight clock should have run fast by 11.46 ns due to
the difference in gravitational potential, slow by 3.03 ns due to velocity, and slow by 0.01 ns due to the
net Sagnac effect, resulting in a total flight clock change of 8.42 ns (fast). Preliminary measured test
results, after calibrating the estimated clock drift between the two clocks, showed that the flight clock ran
fast by 8.3 ns relative to the ground clock.
The difference between the predicted and measured values is
consistent with clock noise on the order of a few parts in 1014 over the flight time interval. The
anomalous dip of about 3 ns at time 9,000 s is not inconsistent with typical cesium clock behavior."
There are multiple examples all showing the clocks running faster. This is a fact, we have to modify clocks orbiting the Earth because they run fast when compared to the ground clocks.
On page 204, the ISS and TopEx satellites have greater velocity
time dilation than gravitational red shift so their clocks run slower.
SR is an observer dependent theory and is kind of nonsense though so not
sure how that velocity time dilation comes about. Could be some mechanical
attribute of the clock or could be real time dilation.
What is the difference? This sounds to me like two ways of stating exactly the same result. You can probably see this by stating it more accurately, because neither the second nor the meter are doing anything. They are simply units of measurement and not physical actors. What you should really be asking is "Does X travel 2 meters over the course of 1 second or does X experience the passage of 1 second over the course of traveling 2 meters?" The answer is both; each statement is equivalent to the other.
I agree that both statements are equivalent to each other.
My question concerned the mechanics of velocity.
For example, let's say we have a long length of rubber tubing. This tubing will represent one second. We are on a city block and there is a fire hydrant midway between every intersection. The tubing is currently stretched along a length of one block, from one intersection to the next. It can therefore be said that the 'rate' at which we encounter fire hydrants is one hydrant per second (or one second per hydrant). Now let's say we want to double the rate at which we encounter fire hydrants. This can be accomplished by stretching the rubber tubing out to the next intersection, thereby placing another fire hydrant alongside the same one second. Or we can call city hall and have another fire hydrant erected alongside the rubber tubing as it currently is.
Both actions have the same result - the rate is increased to 'two hydrants per second,' but they are different mechanically. I originally envisioned that velocity was like the former, where if we are dealing with meters instead of city blocks, a doubling of velocity is a stretching of one second over twice the distance. I hoped that this would have built in relativity, as the stretching of one second would effectively apply to observers. If a stretched second for a rocketship is three times longer with respect to an observer's then, from the observer's point of view, he ages three seconds for every one the spaceship crew does. I then read that time dilation is not a linear relation.
The only other possibility I could think of was that a shrinking of distance units accompanied a stretch in time (with respect to an observer). This was confirmed by Dr. Halpin-Healy.
I made a drawing to show what I am referring to:
http://img409.imageshack.us/img409/303/timesp5.png
As before, black is distance and red is time.
Figure 1 is the base velocity, used for comparison, one distance unit per second.
Figure 2 is the velocity increased to 2 units per second. The time unit is constant but distance is compressed.
Figure 3 is also 2 units per second. In this figure the distance unit is constant but time is stretched.
As you can see, figures 2 and 3 both represent 2 units per second, but are fundamentally different.
Both retain one component from the base velocity but need to alter the other to double the velocity.
They are only different "mechanically" (to use your expression) because you have an in-built frame of reference against which you can measure both the length of tubing and the separation of fire hydrants - the city blocks. Take away that frame of reference and you are left with just tubing and hydrants - and now there is absolutely no difference between "doubling the number of hydrants per length of tubing" and "stretching the tubing to extend along twice as many hydrants" - the two operations are equivalent.
They only become inequivalent when you insert another reference frame, such as the city blocks, against which you can compare either or both hydrants and tubing.
Best Regards
What is fundamental velocity?
Fundamental velocity refers to the velocity of an object relative to a fundamental reference frame, typically the speed of light in a vacuum.
How is fundamental velocity different from other velocities?
Fundamental velocity is a universal constant that cannot be exceeded, whereas other velocities may vary depending on the observer's frame of reference.
Why is fundamental velocity important in physics?
Fundamental velocity is a fundamental concept in physics and is crucial in understanding the behavior of objects in the universe, especially at high speeds and in the realm of relativity.
Can fundamental velocity be measured?
Yes, fundamental velocity can be measured using various methods such as time-of-flight measurements or Doppler effect measurements.
How does fundamental velocity relate to the theory of relativity?
Fundamental velocity is a key component of Einstein's theory of relativity, where it is used to explain the relationship between space and time and the behavior of objects at high speeds.
