machiner13
- 1
I am designing a fusable link for the axle shafts on my atv and I am having trouble calculating the torsional strength of my fuse. I want the fuse to fail at about 80% of what the axle shaft would fail at. The axle shaft is .875 inch diameter 4140 alloy steel that has been annealed and quenched to give it a Bhn hardness of 555 on the OD and 286 near the center. The fuseable link body will be made of 4140 alloy steel with a diameter of 1.00 inch inside of a collar with an outer diameter of 1.5 inches. Both peices of the fuseable link body will be annealed and quenched, then tempered to have a finished Bhn hardness of 380. The fuseable link body will have a .390 inch diameter hole that passes through the center of the 1.5 dia collar and the 1. dia to receive a Grade 5 bolt 3/8 diameter. The bolt will be the fuse. My question is, will the bolt be the weakest link and how do I convert the shear strength of the bolt into torque in order to compare it with the torque it would take to break the axle?
