Fusion Power: Breaking the Coulomb Barrier
In summary: A closed shell of neutrons and protons is particularly stable. For example, the closure of the 1g9/2 shell at N = 50, Z = 28 results in the most stable of all nuclide, namely Sn-100. The closure of the 1j15/2 shell at N = 82, Z = 50 results in the second most stable nuclide, namely Pb-208. The half-lives of these nuclides, and others in these shells, are on the order of billions of years, and some are considered stable. In summary, The main problem with achieving fusion for power is the Coulomb Barrier, which requires high temperatures and plasma pressure. The energy losses
  • #36
vanesch said:
actually, if I understand correctly, there are small chemical differences between heavy water and light water, and indeed, if about 25-50% of your body water would be heavy water, several metabolical processes would be disturbed. As such, heavy water is "toxic" in a very very slight way, but if you would drink for more than a month of so *nothing else but* heavy water, you'd probably die or get seriously ill.
Drinking a glass (or a bottle) of heavy water is no problem. Drinking two bottles probably not, either. But drinking *only* heavy water for an extended period of time would be lethal.
this really isn't hard to imagine, since many (if not most) enzymes utilize water as an electron donor in their catalysis. given that the vibrational modes of D2O will be substantially different than that of H2O some enzymes may not function correctly. (infact, a friend of mine uses this isotope effect to study the reaction mechanism of enzymes - in particular the rxn rate kinetics).
<h2>1. What is fusion power and how does it work?</h2><p>Fusion power is a type of nuclear energy that is created by fusing two or more atomic nuclei together to form a heavier nucleus. This process releases large amounts of energy, which can then be harnessed for electricity generation. In order for fusion to occur, the nuclei must overcome the Coulomb barrier, which is the force of repulsion between positively charged nuclei.</p><h2>2. What is the Coulomb barrier and why is it important in fusion power?</h2><p>The Coulomb barrier is the force of repulsion between positively charged nuclei. This barrier must be overcome in order for fusion to occur. It is important in fusion power because it is the main obstacle that scientists must overcome in order to achieve sustained fusion reactions and produce usable energy.</p><h2>3. How do scientists plan to break the Coulomb barrier in fusion power?</h2><p>Scientists plan to break the Coulomb barrier in fusion power by using extremely high temperatures and pressures to force the nuclei close enough together to overcome the repulsive force. This is achieved through the use of powerful magnets and specialized containment vessels, such as tokamaks, to create a plasma state where fusion can occur.</p><h2>4. What are the potential benefits of fusion power?</h2><p>Fusion power has the potential to provide a nearly limitless source of clean energy. It produces no greenhouse gas emissions, does not produce long-lived radioactive waste, and does not rely on limited resources like fossil fuels. Additionally, fusion reactions release millions of times more energy than traditional chemical reactions, making it a highly efficient energy source.</p><h2>5. What are the current challenges in achieving fusion power?</h2><p>The main challenges in achieving fusion power include the high temperatures and pressures needed to overcome the Coulomb barrier, as well as the difficulty in containing and controlling the extremely hot plasma. Other challenges include finding suitable materials that can withstand the extreme conditions, and developing cost-effective methods for producing and maintaining the necessary equipment.</p>
  • Nuclear Engineering
  • Quantum Physics
  • Electrical Engineering
