G.726 ADPCM implementation
  1. Oct 13, 2004 #1
    [Urgent] G.726 ADPCM implementation
    I'm trying to implement G.726 ADPCM using the source codes released by Sun Microsystems to the public domain. I subsequently tested my program using the test vectors released by ITU but there were many errors (ie discrepancies between the ADPCM codewords generated by my prog and the ITU-given codewords).
    Can anyone who is experienced in the above implementation advise me on how can I go about debugging my program. I had spent 4 days trying to solve the problem but to no avail!!
    ps. the codes released by Sun is for the the implementation for G.721 but it is similar to what i want (ie 32kbps) so i believe it's safe to use it directly. or am i wrong?
    static short qtab_721[7] = {-124, 80, 178, 246, 300, 349, 400};
    static short _dqlntab[16] =
    -2048, 4, 135, 213, 273, 323, 373, 425,
    425, 373, 323, 273, 213, 135, 4, -2048
    static short _witab[16] =
    -12, 18, 41, 64, 112, 198, 355, 1122,
    1122, 355, 198, 112, 64, 41, 18, -12
    static short _fitab[16] =
    0, 0, 0, 0x200, 0x200, 0x200, 0x600, 0xE00,
    0xE00, 0x600, 0x200, 0x200, 0x200, 0, 0, 0
    // static short _fitab[8] = {0, 0, 0, 1, 1, 1, 3, 7};
    * Encodes the input value of linear PCM, A-law or u-law data sl and returns
    * the resulting code. -1 is returned for unknown input coding value.
    int ADPCM_encoder(int sl, int in_coding, struct g72x_state *state_ptr)
    short sezi, se, sez; // se is the estimated signal
    short d; // SUBTA => Compute diff signal by subtracting signal estimate
    // from input signal (or quantized reconstructed signal in decoder)
    short sr;// ADDB => Addition of quantized diff signal and signal estimate
    // to form reconstructed signal
    short y; // MIX => Form linear combination of fast and slow
    // quantizer scale factors
    short dqsez; // ADDC => Obtain sign of addition of quantized diff signal
    // and partial signal estimate
    short dq, i;
    static int count = 0;
    FILE *debugPtr;
    debugPtr = fopen("sad.txt", "a");
    switch (in_coding)
    { // linearize input sample to 14-bit PCM
    case AUDIO_ENCODING_ULAW:
    sl = ulaw2linear((unsigned char)sl) >> 2; // sl is complement of orig codeword?
    break;
    case AUDIO_ENCODING_ALAW:
    sl = alaw2linear((unsigned char)sl) >> 2;
    break;
    case AUDIO_ENCODING_LINEAR:
    sl >>= 2; // 14-bit dynamic range
    break;
    default:
    return (-1);
    // * ADAPTIVE PREDICTOR *
    sezi = predictor_zero(state_ptr); // computes estimated signal
    // from 6-zero predictor
    sez = sezi >> 1; // right-shift by 1-bit
    se = (sezi + predictor_pole(state_ptr)) >> 1;// computes estimated
    // signal from 2-pole predictor
    // * DIFFERENCE SIGNAL COMPUTATION *
    d = sl - se; // difference between actual and estimated signal
    // * ADAPTIVE QUANTIZER *
    /* quantize the prediction difference */
    y = step_size(state_ptr); // computes quantization step size
    i = quantize(d, y, qtab_721, 7); // quantizes the estimated difference
    // and returns the ADPCM code
    // * INVERSE ADAPTIVE QUANTIZER *
    dq = inv_adapt_quan(i & 8, _dqlntab, y); // quantized est diff
    // * RECONSTRUCTED SIGNAL CALCULATOR *
    sr = (dq < 0) ? se - (dq & 0x3FFF) : se + dq;
    dqsez = sr + sez - se; /* pole prediction diff. */
    fprintf(debugPtr, "%6d %6d %6d %6d %6d %6d\n", sl, se, d, y, i, count++);
    update(4, y, _witab << 5, _fitab, dq, sr, dqsez, state_ptr);
    fclose(debugPtr);
    return (i); // ADPCM codeword
Draft saved Draft deleted
