G force question
  1. May 16, 2007 #1
    Hello,
    Im trying to calculate the amount of G force generated from a golfswing for example. Let's say the swing is carried out with an acceleration of 26rad/sec, and that it is perfectly circular ;)
    Im using formula a = w^2 *r; If my armls add 40cm and I want to know the G force 6cm below my grip...
    a = 26^2 * 0.23 = about 155, divided into 9.82 meters/sec = 16G ,
    That sounds a bit high to me so I would like to know if I am doing something wrong here...
    Br
    /Markus
  3. May 16, 2007 #2
    FredGarvin
    From what you have given, the only thing I see wrong is that you used your arm distance plus 6 cm as a diameter and not a radius. I assume that you are considering your shoulder as the center of the circle.
    Your angular velocity (not acceleration) of 26 rad/sec is moving pretty quickly. It's almost 250 rpm.
  4. May 16, 2007 #3
    Aa that's right, so the correct value should be more something like 26^2*0.46 then... that's more like 30G,
    I got the value 26rad/sec from some golfing website, it might be wrong, but the pro's can reach a speed of 100mph at the tip of the club, not sure how to convert that into rad/sec though.
    /Markus
  5. May 16, 2007 #4
    FredGarvin
    It wouldn't be to tough to do an experiment to see how good your numbers are. A spring scale and a weight to mimic the club would do it.
    30 G sounds a bit high, but not totally unreasonable.
  6. May 16, 2007 #5
    AlephZero
    100 mph = 160 km/h = 160*1000/3600 m/s = 45 m/s
    Angular velocity = v/r where r is the total radius (length of arm + club). From the size of a normal person, r must be a bit less than 2m, say 1.8m
    Angular velocity = 45/1.8 = 25 rad/sec.
    So your numbers seem consistent.
    The golfer doesn't actually feel the "G" value as an acceleration, he/she only feels the force. An acceleration of 30G on a 1Kg object gives a force of 30 Kgf. (I'm not a golfer but 1 Kg sounds too much for the mass of a golf club). A fit person can easily lift his/her body weight with his/her arms, so a 30 Kgf force seems quite reasonable.
