Game Collision Physics
I am currently programming a 2-dimensional game and am creating a class that will allow for collision detection with any polygon defined by a set of points. The actual collision detection was easy, however i am having trouble coming up with an equation to describe the resulting velocity vector of an object after the collision.
http://www.cheeseparade.com/diagram.png [Broken]
Based on the diagram above, can anyone give me an equation that will return the blue vector as a function of the green vector, regardless of the angle of the green vector? All the red points are known information at any given time.
Thanks,
Madison
Answers and Replies
diazona
2,175
I'm not quite sure what I'm looking at here... what should the relationship be between the blue vector and green vector? Or in other words, what kind of physical situation are you trying to simulate? What happens to the object that collides with the polygon?
when the object collides, the component of its velocity that is perpendicular to the edge that it collides with should be eliminated so that the object continues on a path parallel to the edge. i dont need to worry about bouncing at this point.
diazona
2,175
OK, I see... you're talking about a totally inelastic collision. I'm assuming you have (or can calculate) the velocity vector [itex]\vec{v}[/itex] as well as the vector pointing along the edge of the polygon in the direction of the blue arrow, which I'll call [itex]\vec{p}[/itex], and also that you either have or can write a function to take dot products. Then you can just project [itex]\vec{v}[/itex] on to [itex]\vec{p}[/itex] to get your final velocity:
[tex]\vec{v}\,' = \frac{\vec{v}\cdot\vec{p}}{\vec{p}\cdot\vec{p}}\ \vec{p}[/tex]
Incidentally, a general formula for inelastic collisions can be found on Wikipedia, http://en.wikipedia.org/wiki/Coefficient_of_restitution.
Thank you! that equation worked perfectly.
Related Threads on Game Collision Physics
  • Last Post
12K
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
