Homework Help: Gamma function as solution to an integral
  1. Feb 26, 2007 #1
    Calculate [tex]\int_0^{\frac{\pi}{2}} \frac{1}{\sqrt{1+\sin^2 x}} dx[/tex] expressing its solution in terms of the gamma function. It's suggested to first use the change of variable [itex]\sin x = t[/itex]
    2. Relevant equations
    The gamma function is defined as [tex]p>0, \Gamma(p)=\int_0^\infty x^{p-1} e^{-x} dx[/tex]
    3. The attempt at a solution
    After using the suggested change of variable the integral is transformed into [tex]\int_0^1 \frac{dt}{\sqrt{1-t^4}}[/tex]
    I then considered using [itex]1-t^4=e^{2y}[/itex] such that the integrand, without yet considering the factor from transforming the differential, would become [itex]e^{-y}[/itex], with the hope that the differential would provide the necessary factor to fit the definition of the gamma function. Unfortunately, the differential turns out to be [tex]dt=\frac{-e^{2y}dy}{2{\left(e^{2y}-1\right)}^\frac{3}{4}}[/tex] which obviously isn't simplifying things at all.
    Several more variations along this line of thinking followed with similar results.
    Also tried [itex]1-t^4=y^a e^{b y}[/itex] which results in [tex]\int \frac{-(a y^{a/2-1}+b y^{a/2})e^{by/2}dy}{4(1-y^ae^{by})^\frac{3}{4}}[/tex] which still isn't getting close to the form of the gamma function.
Draft saved Draft deleted
Loading...
Similar Threads for Gamma function solution Date
Gamma Function Identities Sep 14, 2017
Integral using the gamma function Apr 17, 2017
Show two inequalities - (context gamma function converges) Jan 12, 2017
Sterling approximation of Beta Function Nov 1, 2016
