Understanding the Gamma Function in Complex Numbers
In summary, The Gamma function only converges for real values greater than 0, but it can be extended to a larger domain using analytic continuation. This is relevant when using the Gauss formula for complex parameters, as it is only valid for certain conditions, such as when the real part of c-a-b is greater than 0 and c is not equal to certain negative integers. However, even in cases where these conditions are not met, the gamma functions may still be defined. Further research is necessary to determine if the stated conditions are sufficient for the Gauss formula to be valid.
Ted123
446
If the Gamma function [tex]\Gamma (z) = \int_0^{\infty} t^{z-1} e^{-t}\;dt[/tex] only converges for [itex]\text{Re}(z)>0[/itex] then why is, for example, [itex]\Gamma (-1+i)[/itex] defined when clearly [itex]\text{Re} (-1+i)<0[/itex] ?
You are correct, the integral formula does not converge if the real part is less than one. This is why it is useful to use the analytic continuation of the gamma function. In other words, we can a way to extend the domain of the gamma function. Take a look at the following for more information (this is somewhat beyond my area of expertise, at the moment),
http://en.wikipedia.org/wiki/Gamma_function#The_gamma_function_in_the_complex_plane
The book that I've got says that the Gauss formula for complex parameters a,b,c: [tex]\displaystyle _2 F_1 (a,b;c;1) = \frac{\Gamma (c) \Gamma (c-a-b)}{\Gamma (c-a) \Gamma (c-b)}[/tex] is valid for [itex]\text{Re}(c-a-b)>0,\;c\neq 0,-1,-2,-3,...[/itex].
But if a=1, b=-0.6 and c=-0.5 for example then all the gamma functions appear to be defined (or aren't they?) yet [itex]\text{Re}(c-a-b) = -0.9 \not > 0[/itex] [tex]\displaystyle \frac{\Gamma (-0.5) \Gamma (-0.9)}{\Gamma (-1.5) \Gamma (0.1)}[/tex] seems to be all defined to me?
Are the conditions [itex]\text{Re}(c-a-b)>0,\;c\neq 0,-1,-2,-3,...[/itex] sufficient for the Gauss formula to be valid?
What is the gamma function in complex numbers?
The gamma function is a mathematical function that generalizes the factorial function to non-integer values, including complex numbers. It is denoted by the Greek letter gamma (Γ) and is defined as Γ(z) = ∫0 xz-1 e-x dx, where z is a complex number.
What is the significance of the gamma function in complex analysis?
The gamma function is an important tool in complex analysis because it extends the concept of factorial to non-integer values, allowing for the evaluation of integrals and series involving complex numbers. It also has many applications in fields such as physics, engineering, and statistics.
How is the gamma function related to the factorial function?
The gamma function is a generalization of the factorial function, meaning that for positive integers n, Γ(n) = (n-1)! This relationship allows for the extension of the factorial function to non-integer values.
What are the properties of the gamma function in complex numbers?
The gamma function has many properties, including the reflection formula, the duplication formula, and the recurrence relation. It is also an entire function, meaning that it is analytic everywhere in the complex plane.
How is the gamma function used in solving problems involving complex numbers?
The gamma function is used to evaluate integrals and series involving complex numbers, as well as to solve equations and differential equations. It also has applications in probability and number theory. Additionally, the gamma function is used in the definition of other important functions, such as the beta function and the zeta function.
