Gamma matrices
  • Thread starter bubblehead
I've just started a masters in physics after a 4-year break and am having some real trouble getting back into the swing of things! We have been asked to prove some properties of gamma matrices, namely:
1. [itex]\gamma^{\mu+}=\gamma^{0}\gamma^{\mu}\gamma^{0}[/itex]
2. that the matrices have eigenvalues +/- 1, +/- i
3. The trace of [itex]\gamma^{\mu}[/itex] is zero
4. if [itex]\gamma_{5} = -i\gamma^{0}\gamma^{1}\gamma^{2}\gamma^{3}[/itex] then [itex]\gamma_{5},\gamma^{\mu}[/itex]= 0, [itex]\gamma^{2}_{5}[/itex]=I, eigenvalues = +/- 1
For #1 we are to use the Clifford algebra. We have not been given the definitions of the the gamma matrices -- I don't know if we are expected to know these or if they are irrelevant for the proof. We are also given that gamma 0 is equal to its conjugate transpose and gamma i (i = 1,2,3) is equal to its conjugate transpose times -1. I don't even know where to start on this one -- not quite clear on how the multiplication of the matrices works.
#2 I can do if I take each matrix individually, but how do it do it for the 'general' case of [itex]\gamma^{\mu}[/itex]? By [itex]\gamma^{\mu}[/itex] does it mean I need to take all gammas at once as a set/group/4-vector (how can it be a vector if its components are matricies?), or does it mean for a general gamma mu, where mu = 0,1,2,3?
#3 Same as above, fine if I take each matrix individually, but how to do it generally?
# 4 I can do the eigenvalues and the gamma-five-squared = identity, but I'm not sure about the commutator? Again, do I use some 'general' gamma mu?
I have never had to use tensors before so that whole area is still not quite clear to me -- I understand the concept but not really how tensor operations work.
Answers and Replies
phyzguy
1,507
You will need to use the defining property of the gamma matrices, namely:
[tex]\gamma^\mu \gamma^\nu + \gamma^\nu \gamma^\mu = 2 \eta^{\mu\nu}[/tex]
Most of these should follow from this. For example, this tells you that
[tex] (\gamma^0)^2 = 1, (\gamma^i)^2 = -1[/tex]
What can you conclude about the eigenvalues from this?
As they are unitary matrices, it means the eigenvalues are +/- i, +/- 1. Hooray!
I am still stuck on how to show 1.
Using the defining property I can generalize, ([itex]\gamma^{\mu}[/itex])[itex]^{2}[/itex]=[itex]\eta^{\mu\mu}[/itex]. I am given the conjugate transposes for 0 and i, putting those together I get
[itex]\gamma^{\mu+}[/itex]=-[itex]\eta^{\mu\mu}\gamma^{\mu}[/itex]
I can substitute ([itex]\gamma^{\mu}[/itex])[itex]^{2}[/itex] for [itex]\eta^{\mu\mu}[/itex]. For -1 I can substitute the square of gamma zero, giving
[itex]\gamma^{\mu+}[/itex]=[itex]\gamma^{\mu}\gamma^{\mu}\gamma^{0}\gamma^{0}\gamma^{\mu}[/itex]
How do I continue from here? I am stuck on how to rearrange this because the matrices are not commutative. I tried substituting a rearranged defining property for [itex]\gamma^{0}\gamma^{\mu}[/itex] but it didn't seem helpful.
vela
Staff Emeritus
Education Advisor
14,658
1,292
Use the anticommutation relation to switch the order of [itex]\gamma^0[/itex] and [itex]\gamma^\mu[/itex] in [itex]\gamma^0\gamma^\mu\gamma^0[/itex]. It doesn't matter which [itex]\gamma^0[/itex] you use.
Not sure how to do that. Everything I try seems to just cancel back out, e.g.
[itex]\gamma^{0}\gamma^{\mu}\gamma^{0}[/itex] = [itex]\gamma^{0}[/itex](2[itex]\eta^{\mu 0}[/itex]-[itex]\gamma^{0}\gamma^{\mu}[/itex])
=[itex]\gamma^{0}[/itex]2[itex]\eta^{\mu 0}[/itex]-([itex]\gamma^{0}[/itex])[itex]^{2}\gamma^{\mu}[/itex]
= [itex]\gamma^{0}[/itex]([itex]\gamma^{\mu}\gamma^{0}+\gamma^{0}\gamma^{\mu}[/itex])+[itex]\gamma^{\mu}[/itex]
=[itex]\gamma^{0}\gamma^{\mu}\gamma^{0}[/itex]+[itex]\gamma^{0}[/itex])[itex]^{2}\gamma^{\mu}[/itex]+[itex]\gamma^{\mu}[/itex]
How does this help me?
vela
Staff Emeritus
Education Advisor
14,658
1,292
What does the second line evaluate to when [itex]\mu=0[/itex] and when [itex]\mu=i[/itex]?
Related Threads on Gamma matrices
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
