Find the Ideal Width for a Rectangular Vegetable Garden
In summary, the possible values of x for the width of the alley are between 1 and 2 meters, in order for the area of the alleys to be greater than 41 square meters and the area of the cultivated part to be greater than 280 square meters. This is found by setting up and solving two inequalities, one for each condition, and then finding the intersection of the two solution sets. The resulting range of values for x is 1 < x < 2 meters.
orangeSLICE
Hi again! :smile:
A gardener has a rectangular vegetable garden which is 30m long and 12m wide. He traces to alleys x meters wide, similar to this:
_____________________
|________| x |________|
x___________ _________
Determine, with x, the area occupied by the alleys and the area occupied by the vegetables.
Determine the possible values of x for the width of the alley so that the area of the alleys is superior to 41 meters squared and so that the cultivated part is superior to 280 meters squared.
Here's what I've got so far:
30-x * 12 - x = cultivated area
360 - 30x - 12x + x = cultivated area
360 - 42x + x squared = cultivated area
So the gardened area is: x squared - 42x
But how do I prove this? Do I need to prove this?
Next, I need help trying to get the values of x. How do I go about doing this?
Sorry if my "garden" is sloppy. I tried to make it look like the book.
Any help is appreciated :redface: Thank you
Mathematics news on Phys.org
What's the difference between the cultivated area and the gardened area?
It should be 42x - x² actually, rather than the other way around.
There is no difference :smile: both names describe the same area. I just don't know how to find the values of the cultivated area and the area of the alleys.
well the area of the cultivated area is 360 - 42x + x².
How did you get 42x - x², or x² - 42x ?
Also the total area of your garden is the sum of the two areas.
You can work out the total area of the garden, yes?
Now subtract the area of the cultivated area to get the area of the alleys.
Um, I'm thinking that 360 is everything cultivated are + alleys. From that I take x² - 42x is the alley area. Am I right?
360 is everything, and as you calculated, 360 - 42x + x² is the cultivated area. So the alley area is everything minus the cultivated area. So to find the alley area, it's:
(360) - (360 - 42x + x²)
how are you getting x² - 42x?
I have no idea. I just took it from the 360-42x+x². :frown:
So I did 360-360+42x-x² and got 42x-x². Now, THAT'S the alley area?
42x - x squared = area of the alleys
360 - 42x + x squared >= 280
42x - x squared >= 41
- 42x + x squared >= -80
x squared - 42x + 80 >= 0
x squared - 42x + 41 <= 0
(x - 40)(x - 2) >= 0
(x - 41)(x - 1) <= 0
(x <= 2) or (x >= 40)
(1 <= x <= 41)
(1 <= x <= 2)
May be the answer is
(1 < x < 2)
I amn't very good in English.
I don't know that means "is sperior to".
i got it
Here's what I found:
-x² + 42x > 41 m
when x = 1
-1 + 42 = 41
so x > 1
360 - 42x + x² > 280 .
x² - 42x > -80
2² - 84 = -80
4 - 84 = -80
-80 = -80
x > 2
Thank you everyone for helping me with this problem! I finally understand it :shy:
-x² + 42x > 41 m
when x = 1
-1 + 42 = 41
so x > 1
x² - 42x > -80
2² - 84 = -80
4 - 84 = -80
-80 = -80
x > 2
here's how to do those inequality bits.
You have,
-x² + 42x > 41
or
x² - 42x +41 < 0
which becomes
(x - 41)(x - 1) < 0
Now, if the product of two terms, (x - 41) and (x - 1) is negative, then one of the terms must be -ve and the other term must be +ve.
( -ve means negative and +ve means positive)
let's asume that
(x - 41) is -ve
(x - 1) is +ve
then
(x - 41) < 0 implies x < 41
(x - 1) > 0 implies x > 1
i.e. 1 < x < 41
now assume that
(x - 41) is +ve
(x - 1) is -ve
then
(x - 41) > 0 implies x > 41
(x - 1) < 0 implies x < 1
but x can't be both less than 1 and greater then 41 at the same time, so this assumption is invalid, so only the other assumption is valid.
Hence, 1 < x < 41 for the alley area to be greater than 41 m²
i.e. 1 < x < 41
The other thing you have is, the cultivated area greater than 280 m².
which becomes
x² - 42x + 80 > 0
(x - 40)(x - 2) > 0
The product of these two terms is +ve, therefore they are both +ve or they are both -ve.
Let's assume both are +ve
(x - 40) > 0 implies x > 40
(x - 2) > 0 implies x > 2
i.e. x must be greater than 40 to make both terms +ve, but maximum size of x can only be 12 m. Therefore this assumption is invalid.
assume that both terms are -ve
(x - 49) < 0 implies x < 40
(x - 2) < 0 implies x < 2
Both terms are -ve for x < 2
Hence, x < 2 for the cultivated area to be greater then 280 m².
Combining these inequalities gives us
1 < x < 2
as the requirement on the size of the alleyways to satisfy the given conditions. viz. that the area of the alleys is greater than 41m² and the area of the cultivated area is greater than 280 m².
1. How do I determine the ideal width for my rectangular vegetable garden?
The ideal width for a rectangular vegetable garden depends on a few factors, including the types of vegetables you plan to grow and the amount of space you have available. Generally, a width of 4-5 feet is recommended to allow for easy access and maintenance. However, you may need to adjust this based on the size of your garden and the spacing requirements of your chosen vegetables.
2. Can I make my rectangular vegetable garden wider than 5 feet?
Yes, you can make your vegetable garden wider than 5 feet if you have the space available. Just be sure to leave enough room between rows for easy access and maintenance. Keep in mind that wider gardens may require more maintenance and watering, so consider this when planning the size of your garden.
3. What is the minimum width for a rectangular vegetable garden?
The minimum width for a rectangular vegetable garden is 3 feet. However, this may not provide enough space for some vegetables to grow properly. It is recommended to have a width of at least 4-5 feet to allow for proper growth and maintenance.
4. Can I have a rectangular vegetable garden with uneven widths?
It is not recommended to have a rectangular vegetable garden with uneven widths, as this can make maintenance and access more difficult. However, if you have limited space, you can consider using raised beds or containers to create a more compact and organized garden.
5. How do I know if the width of my rectangular vegetable garden is suitable for my chosen vegetables?
You can determine if the width of your vegetable garden is suitable by researching the spacing requirements of your chosen vegetables. The width of your garden should allow for enough space between rows and individual plants to ensure proper growth and maintenance. You can also consult with a gardening expert or reference books for specific recommendations for your chosen vegetables.
  • Precalculus Mathematics Homework Help
