Gas expanding against a piston
  • Thread starter Bipolarity
Bipolarity
775
Consider a cylindrical piston in which an ideal gas is kept. The gas is currently at pressure P1, volume V1, and temperature T. The temperature T is assumed to be constant throughout the experiment. The piston is massless and frictionless. On the piston is a block of mass M and this mass is not changed throughout the experiment. The block's cross-sectional area is A. Thus, the pressure of the block on the piston is Mg/A.
Assume that initially P>Mg/A so that the gas begin to expand until its pressure equilibrates with the pressure of the block. Its final volume is V2.
1) Throughout this process, is the pressure of the gas a constant?
2) To calculate the work done by the gas, do you use the gas pressure P or the external pressure Mg/A.
W = F*d
PV = nRT
1) As the gas expands, its pressure must decrease due to Boyle's law such that the product PV is a constant.
2) My textbook says we use the external pressure to calculate work, but I can't understand this. My argument is that to calculate work done by the gas, you need to use the pressure of the gas since it is the gas which is responsible for the force applied in raising the piston.
BiP
Answers and Replies
ehild
15,543
1,915
The pressure of the gas is defined when the gas is in equilibrium. Expanding against the constant external force, the gas is not equilibrium with the surroundings, so pressure is not defined during the process. The gas molecules hit the piston, and exert force on the piston so it will raise, but that makes the molecules loose kinetic energy in the collision with the piston: the local pressure is lower near the piston than far from it. Calculate the work done on the gas by the external force. The negative of this work is done by the gas.
ehild
Suggested for: Gas expanding against a piston
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
