Canister Ignition Protection: How Do Gas Containers Keep Flames from Spreading?
In summary, the fire triangle is something that helps determine how something can burn. This principle works off of the lack of oxygen, which means it won't work with things like hydrogen.
JoeSalerno
79
So, this is just a simple question that crossed my mind. When say, a blowtorch or propane tank is ignited, how does the entire canister not go up in flames? How does the flame only stay on the outside and not burn through to the inside where the gas supply is? Will whatever principle this works off of work for any gas, even something as flammable as hydrogen? Thanks in advance for anyone who knows.
Chemistry news on Phys.org
Do you know what the fire triangle is?
I expected it to be something this simple. Is the fire not able to burn what's in the container simply because there's no oxygen in the container? If so, what would happen if oxygen was one of the gasses in the container?
Yes.
Apply fire triangle again. Preferably keeping the distance though.
Borek said:
Yes.
By keeping the distance, do you mean the gasses would be kept in sepearate containers like a welding torch?
No, I mean don't stand too close to the tank while testing the idea :wink:
In that case, do you have any recommendations for how to ignite it from a distance? Maybe some sort of fuse?
Why do you want to use a bomb in the first place?
I was performing electrolysis with water to get oxygen, and was wondering if it was at all possible to use the excess hydrogen for something like a blowtorch. That's why I was wondering whether it could sustain a flame, or just blow up the canister.
What is wrong about collecting the hydrogen in a tank and mixing it with the air in the burner?
Wouldn't that provide a way for all of the gas to ignite and explode at once instead of fueling a flame?
You have already answered that question in the post #3.
Myth-busters style experimentation. If all else fails add more dynamite.
BoB
Hydrogen, or whatever is in the tank, is contained by a structure made of iron or similar. (though very small amounts can escape)
You'll have to melt the container first before the Hydrogen can react with anything outside of the container.
1. What is gas ignition limitation?
Gas ignition limitation is the maximum amount of gas that can be ignited safely in a confined space without causing an explosion. It is an important safety consideration in many industries, such as oil and gas, chemical, and manufacturing.
2. What factors can affect gas ignition limitation?
There are several factors that can affect gas ignition limitation, including the type of gas, its concentration, temperature, pressure, and the presence of any flammable materials or sources of ignition in the surrounding environment.
3. How is gas ignition limitation determined?
Gas ignition limitation is typically determined through laboratory testing, using specialized equipment and procedures. The results are then used to develop safety guidelines and regulations to prevent accidents and ensure safe handling of gases in various settings.
4. What are the consequences of exceeding gas ignition limitation?
Exceeding gas ignition limitation can lead to an explosion, which can cause serious injuries or fatalities, as well as significant property damage. It can also result in the release of toxic gases and pollutants into the environment.
5. How can gas ignition limitation be managed?
Gas ignition limitation can be managed by implementing safety measures and protocols, such as using proper ventilation systems, monitoring gas levels, and conducting regular maintenance and safety checks. It is also important to train employees and follow industry regulations and guidelines to ensure safe handling of gases.
  • Materials and Chemical Engineering
  • General Engineering
  • General Discussion
  • Other Physics Topics
  • Science Fiction and Fantasy Media
