Gas Law: Pressure & Volume - Hot Air Balloon
In summary: The pressure inside the balloon is constant, but the pressure outside is dropping. So the net force on the balloon walls would increase toward the outside, and the balloon would grow. Of course, that assumes that the temperature is not going down substantially (the problem did not address this explicitly), and that the balloon walls are elastic.In summary, if the pressure remains constant and the temperature decreases, the balloon will grow in volume.
bluegirlbalance
As a hot air balloon rises to increasingly higher altitudes describe what happens to the volume of the balloon if at constant pressure?
My teacher had us do a PTV cards activity, where we took an index card and wrote the letters P(for pressure), T(for temperature), and V(for volume). This activity was supposed to help us learn about pressure. For example, if the pressure increases and the temperature remains constant, what happens to the volume? It increases.
For the question above, if the pressure remains constant as the hot air balloon rises, the volume increases, right?
Correct. PV = nRT.
as the hot air balloon rises, temperature gets lower, right? as temperature drops but all other variables stay the same, volume must drop
berkeman why do you say the volume increases? what am i missing?
PV = nRT
If R is a constant, and temperature remains the same. Moles aren't changing. Therefore, if the pressure goes up, the volume must go down. If the volume went up too, then that would completely change the answer! Do you see why?
But we are supposed to assume a constant pressure according to the question
if the pressure is constant, the only variable changing as the hot air balloon rises, would be it is getting colder, which means less volume
Actually, the more I think about it, I am not sure of the answer. I don't understand what the problem statement means by "what happens to the volume of the balloon if at constant pressure?". What's at a constant pressure? The absolute pressure of the gas inside the balloon?
Hot air balloons are open on the bottom. Volume remains constant. Density of hot air at constant P is less so the balloon is buoyant and rises. At lower external pressures (higher altitude) hot air is forced out the bottom of the balloon and therefore, the number of moles is less. Pressure inside the balloon must be the same as the outside at equilibrium regardless of altitude. If this condition is not met, air will flow from high pressure to low pressure (out the bottom).
This is not the case for Helium balloons where the number of moles of gas remains constant.
I'd go a step further. The balloon is not a closed container, so "volume" is meaningless (undefined). This question is a bunch of hot air!
^i don't think volume is meaningless, the balloon can expand or shrink even with that opening at the bottom, so volume is defined in terms of the balloon
Perhaps the question belongs in the brainteaser section...
To answer the question in the OP, Bluegirl, you are essentially correct that the volume would increase IF we were discussing a helium balloon. Keep in mind that the pressure would be decreasing inside the balloon and outside the balloon as it gained altitude. At some point, the pressure inside the balloon would start to exceed the pressure outside the balloon because the fabric stopped stretching. The balloon would probably fail shortly thereafter...
Helium balloons are launched to high altitude in massive balloons that contain relatively little helium. They look like mostly empty bags with a little bubble of helium at one end. As the balloon rises this small bubble eventually expands to fill the entire balloon (which can be very large).
http://topweb.gsfc.nasa.gov/balloon/launch.html
http://topweb.gsfc.nasa.gov/balloon/launch2.html
1. What is the relationship between pressure and volume in a hot air balloon?
The relationship between pressure and volume in a hot air balloon is known as Boyle's Law. It states that at a constant temperature, the pressure of a gas is inversely proportional to its volume. This means that as the volume of the balloon increases, the pressure of the gas inside decreases, causing the balloon to rise.
2. How does the temperature of the air affect a hot air balloon?
The temperature of the air affects a hot air balloon through Charles's Law. This law states that at a constant pressure, the volume of a gas is directly proportional to its temperature. As the air inside the balloon is heated, it expands and becomes less dense, causing the balloon to rise. On the other hand, if the air cools down, it contracts and becomes more dense, causing the balloon to descend.
3. How does the weight of the hot air balloon affect its flight?
The weight of a hot air balloon affects its flight in two ways. First, the weight of the balloon and its basket must be less than the weight of the displaced air, otherwise the balloon will not be able to rise. Second, the weight of the fuel and passengers must be carefully balanced to maintain stability and control during the flight.
4. Why is it important to monitor and adjust the pressure and temperature in a hot air balloon?
Monitoring and adjusting the pressure and temperature in a hot air balloon are crucial for maintaining a safe and controlled flight. Changes in pressure and temperature can affect the buoyancy and stability of the balloon, and can also impact the rate of ascent or descent. By closely monitoring and adjusting these factors, the pilot can ensure a smooth and safe flight.
5. What safety precautions should be taken when operating a hot air balloon?
Operating a hot air balloon requires careful attention to safety precautions. Some important measures include checking weather conditions before flight, ensuring proper maintenance of the balloon and equipment, having a trained and experienced pilot, and following all regulations and guidelines set by aviation authorities. In addition, it is important to have an emergency plan in place in case of unexpected situations during the flight.
  • Biology and Chemistry Homework Help
  • Classical Physics
