• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Gas Laws
If 0.5 mol of nitrigen gas occupies a volume of 11.2 L at 0 degrees Celsius, what volume will 2 mol of nitrogen gas occupy at the same temperature and pressure?
LowlyPion
3,079
Welcome to PF.
What is your thinking about how to approach the problem?
all i really need help with is the pressure... i have the formula for the problem i think (boyle's law) but i do not know the what the pressure is...
LowlyPion
3,079
What happens when you divide one equation by the other?
i dont know...boyles law states P x V = constant....and i dont know what the pressure is
is 44.8 L/mol is the answer?
nicksauce
1,272
I would almost agree, but it asks for the volume it occupies, not the volume per mol. I get 44.8 L as an answer.
nicksauce
1,272
I don't think Boyle's law applies if the amount of material changes. I would think the ideal gas law should be applied instead. PV=nRT (n = number of moles, R = gas constant, T = temperature).
alrighty, thanks...
Should Boyle's Law be used in this problem, since the temperature remains constant:
What is the volume of an ideal gas at 1 atm, 12 L, and 25 degrees Celsius if the pressure is decreased to 0.8 atm at 25 degrees Celsius?
nicksauce
1,272
Yes.
2,981
May I recommend that instead of memorizing or search for different laws for different problems you could simply ALWAYS apply the Ideal Gas Law since ,Charles', Boyles' and Avagadro's Laws are simply special cases of the I.G. Law.
LowlyPion
3,079
Strictly speaking you should consider using the Ideal Gas Law PV = nRT.
To find unknowns in situations that some things change and others don't, then divide the two equations such that
P1V1/P2V2 = n1R1T1/n2R2T2
Just cross out the things that don't change between 1 and 2.
is the answer v2=15 L?
yes, is that the answer to the following: What is the volume of an ideal gas at 1 atm, 12 L, and 25 degrees Celsius if the pressure is decreased to 0.8 atm at 25 degrees Celsius?
Related Threads for: Gas Laws
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
14K
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
