Mango12
- 49
I need to prove that the field charge of 2 infinite, oppositely charged plates is 0 using Gauss' law. I know that the sum of E=4PiK(Sum of q) but I don't know how to prove the charge is 0.
What is a "field charge?" Generally you only have the total charge being 0 when you have equal and oppositely charged plates, so that will be a given when the problem is posed.I need to prove that the field charge of 2 infinite, oppositely charged plates is 0 using Gauss' law. I know that the sum of E=4PiK(Sum of q) but I don't know how to prove the charge is 0.
-Dan
Again, the total charge of the two plates is 0 if and only if they both have the same charge on them. This makes no sense. Can you please post the whole question?Field charge is the total charge. And I need to find the charge on the outside of the plates. I know it would be 0, so maybe I have to set 2 equations equal to each other and show that they cancel to equal 0?
Note: In your first post above you mention the E field due to a distribution of charged particles. When dealing with a parallel plate capacitor you are dealing with a continuous charge distribution so that formula cannot be used.
-Dan
"There are 2 infinite plates side by side. One plate has a negative charge and the other has an equal charge, only positive. Using Guass' Law or the superimposition of fields, calculate the charge on the OUTSIDE of the plates"
What do you mean exactly by Gauss's law?
For a point charge $q$, we have $E=\frac{q}{4\pi\epsilon_0 r^2}$.
More generally, Gauss's law says that the surface integral of $E$ is equal to the enclosed charge $Q$ divided by $\epsilon_0$:
$$\bigcirc\!\!\!\!\!\!\!\!\iint E\cdot dS = \iiint \frac\rho{\epsilon_0} dV= \frac Q{\epsilon_0}$$
I may be going on a rampage, but suppose we look at just one plate with charge $Q$ in a cross section of area $A$.
And suppose we define a cylinder with the plate in the middle, a cross section with area $A$, and a distance $d$ to each end of the cylinder.
Then due to symmetry, we have that the surface integral is $2\cdot E \cdot A$.
Gauss's law says that this is equal to $\frac {Q}{\epsilon_0}$.
So:
$$2EA = \frac {Q}{\epsilon_0} \quad\Rightarrow\quad E = \frac{Q}{2\epsilon_0 A}$$
Are you still with me?
Or am I going on a rampage? (Wondering)
