Gauss' Law and magnitude of the electric field
In summary, the magnitude of the electric field at a radial distance of 3.5 cm from the axis of the cylinder is approximately 3.6 N/C, while at a radial distance of 5.5 cm, it is approximately 6.3 N/C. These values were calculated using Gauss' Law and taking into account the nonuniform volume charge density of the cylinder.
DivGradCurl
372
A long, nonconducting, solid cylinder of radius 4.5 cm has a nonuniform volume charge density that is a function of the radial distance r from the axis of the cylinder, as given by [tex]\rho = A r^2[/tex], with [tex]A = 3.0 \mbox{ }\mu C/\mbox{m}^5[/tex].
(a) What is the magnitude of the electric field at a radial distance of 3.5 cm from the axis of the cylinder?
Gauss' Law:
[tex]\Phi _{\mbox{Net}} = \oint \vec{E} \cdot d\vec{S} = \int _{\mbox{Sides}} \vec{E} \cdot d\vec{S} = ES =\frac{Q_{\mbox{Enc}}}{\epsilon _0} [/tex]
Let a = 3.5 cm. Then:
[tex]E\left( 2\pi a L \right)=\frac{\rho \left( \pi a^ 2 L \right)}{\epsilon _0} \Longrightarrow E = \frac{\rho a}{2\epsilon _0} = \frac{Aa^ 3}{2\epsilon _0} \approx 7.3 \mbox{ } \frac{N}{C}[/tex]
This is wrong, but I don't know where.
(b) What is the magnitude of the electric field at a radial distance of 5.5 cm from the axis of the cylinder?
Gauss' Law:
Let b = 5.5 cm. Then:
[tex]E\left( 2\pi b L \right)=\frac{\rho \left( \pi R^ 2 L \right)}{\epsilon _0} \Longrightarrow E = \frac{\rho R^2}{2b\epsilon _0} = \frac{AR^ 4}{2b\epsilon _0} \approx 1.3 \times 10 \mbox{ } \frac{N}{C}[/tex]
Any help is highly appreciated
Dear thiago_j
I think the way you apply Gauss' Law in general is correct. The one thing that is wrong for sure is your calculation of the enclosed charge.
As you mentioned the charge density is a function of the radius. In your calculations you ignore this. You just take the volume (with radius a) and act as if the whole cylinder had the density it has at radius a, which is not the case (as you stated).
So, in order to calculate the charge enclosed you need to integrate!
Some hints on how to do this: In general, proceed as you always do with integration. Take a certain radius r, calculate the volume of the hollow cylinder with radii r and r+dr and calculate the charge on this infinitesimal hollow cylinder. Then do the integration over the whole volume needed.
I hope it was useful.
Best regards...Cliowa
[tex]Q_{\mbox{Enc}} [/tex] is not [tex]\rho \left( \pi a^ 2 L \right)[/tex]
it is
[tex] \int_0^r \ ( Ar^2 )2 \pi r dr L[/tex]
How about now?
Gauss' Law:
[tex]{Q_{\mbox{Enc}} = \int _0 ^a \left( Ar^2 \right) 2\pi r L \: dr = 2\pi LA \int _0 ^a r^3 \: dr = \frac{\pi LA a^ 4}{2}[/tex]
and so
[tex]E\left( 2\pi a L \right)= \frac{\pi LA a^ 4}{2\epsilon _0} \Longrightarrow E = \frac{A a^3}{4\epsilon _0} \approx 3.6 \mbox{ } \frac{N}{C}[/tex]
Gauss' Law:
Let b = 5.5 cm and R = 4.5 cm. Then:
[tex]{Q_{\mbox{Enc}} = \int _0 ^R \left( Ar^2 \right) 2\pi r L \: dr = 2\pi LA \int _0 ^R r^3 \: dr = \frac{\pi LA R^ 4}{2}[/tex]
and so
[tex]E\left( 2\pi b L \right)= \frac{\pi LA R^ 4}{2\epsilon _0} \Longrightarrow E = \frac{A R^4}{4b\epsilon _0} \approx 6.3 \mbox{ } \frac{N}{C}[/tex]
Appears correct.
1. What is Gauss' Law and how is it related to the magnitude of the electric field?
Gauss' Law is a fundamental law in electromagnetism that relates the electric field to the distribution of electric charges. It states that the electric flux through a closed surface is equal to the net electric charge enclosed by that surface. Mathematically, it can be expressed as ∮E·dA = Q/ε0, where E is the electric field, dA is the differential area element, Q is the net charge enclosed, and ε0 is the permittivity of free space. This law can be used to calculate the magnitude of the electric field due to a given charge distribution.
2. How is Gauss' Law applied to determine the magnitude of the electric field of a point charge?
Gauss' Law can be applied to determine the magnitude of the electric field of a point charge by using a Gaussian surface, which is an imaginary surface that encloses the point charge. The electric flux through this surface is equal to the net charge enclosed by the surface, and since the electric field is constant over a spherical Gaussian surface, the equation simplifies to E·4πr2 = Q, where r is the distance from the point charge to the surface. This allows us to solve for the magnitude of the electric field as E = Q/4πε0r2.
3. How does the magnitude of the electric field vary with distance from a point charge?
The magnitude of the electric field varies inversely with the square of the distance from a point charge. This means that as the distance from the charge increases, the magnitude of the electric field decreases. This relationship is described by Coulomb's Law, which states that the force between two point charges is directly proportional to the product of the charges and inversely proportional to the square of the distance between them. Since the electric field is a measure of the force per unit charge, the same relationship applies to the magnitude of the electric field.
4. Can Gauss' Law be used to calculate the magnitude of the electric field for any charge distribution?
Yes, Gauss' Law can be used to calculate the magnitude of the electric field for any charge distribution, as long as the charge distribution is symmetric. This means that the electric field must be constant over the surface of the Gaussian surface. In cases where the charge distribution is not symmetric, other methods, such as integration, must be used to calculate the electric field.
5. How does the magnitude of the electric field change if the charge distribution is changed?
The magnitude of the electric field will change if the charge distribution is changed, as the electric field is directly proportional to the charge. If the magnitude of the charge is increased, the electric field will also increase, and vice versa. However, the direction of the electric field may also change depending on the arrangement of the charges. Additionally, if the charge distribution is changed such that it is no longer symmetric, the electric field must be calculated using other methods such as integration or superposition.
