Gaussian Beam focused using a lens
  1. Dec 4, 2008 #1
    Hello, I'm really confused about this one, =(
    Suppose I have a guassian beam that is colliminated (beam expanded) and then suppose i let it passed through a lens to focus it.
    Given an initial waist and focal length of the lens. How can i find the waist (or half width) at the focus?
    2. Relevant equations
    3. The attempt at a solution
    There's an approximation using the formula above
    w(z)=(lambda*z)/(pi*w0)
    where w0 is the waist at focus and z is the distance from it, so if i let z=f i can solve for w0
    but this only works if z >> pi(w0)/lambda
    how about for the case when z is small (or the focal length is small), i cant seem to solve it using the above equations.
    Thanks~ ^^;
  3. Dec 8, 2008 #2
    Redbelly98
    Staff Emeritus
    Welcome to PF! :smile:
    Sorry about the late reply, don't know how I missed your question earlier.
    There's another equation for the angle of a Gaussian beam, given it's wavelength and waist size (at the focus). You can use that, as long as the focal length is much much longer than ZR -- and you can verify if that's true after you have found wo at the focus.
    EDIT: Oh, I see you want a more general result, one that does not assume f>>ZR . Hang on while I check in my old Lasers textbook ... I'll post back soon
    EDIT #2: Okay. What you want is to look up the "q parameter" for Gaussian beams, and how ABCD matrices can be used in calculating Gaussian beam propagation. Do you have a textbook that discusses these in detail?
  4. Dec 10, 2008 #3
    looked up the 'q parameter' and you're right~
    Just need the Matrix ABCD to calculate the beam parameters at any z.
    thank you! ^^
Similar Discussions: Gaussian Beam focused using a lens
  1. Gaussian Laser Beam (Replies: 3)
Loading...
