How to Normalize the Quantum Harmonic Oscillator Wave Function?
21joanna12
when considering the quantum harmonic oscillator, you get that the wave function takes the form
psi=ae^{-\frac{m\omega}{2\hbar}x^2}
I have been trying to integrate \psi ^2 to find the constant a so that the wave function is normalised, and I know the trick with converting to polar coordinates to integrate e^{-x^2}, but I cannot figure out how to integrate the more complicated version above. I know that the constant should have the value \left(\frac{m\omega}{\pi \hbar}\right)^{\frac{1}{4}} if the wavefunction is to be normalised, but I can't figure out how to do this?
Thank you in advance!
You have
\int_{-\infty}^{\infty} e^{- c x^2} dx
Make the substitution ##\tilde{x} = \sqrt{c} x##, ##d\tilde{x} = \sqrt{c} dx##, and you get
\frac{1}{\sqrt{c}} \int_{-\infty}^{\infty} e^{- \tilde{x}^2} d\tilde{x}
Use the substitution y=\sqrt{\frac{m\omega}{2\hbar}} x and check the proof here!
\psi=ae^{-\frac{m\omega}{2\hbar}x^2}
Do you want the x^2 in your expression for \psi? If not then the comments above should serve you well: if you do, are you really trying to integrate something
<br /> \propto \int_{-\infty}^\infty e^{-cx^4} \, dx<br />
