• Support PF! Buy your school textbooks, materials and every day products Here!
Gauss's Law in Cartesian Help
I'm running through the following problem in an EM text of mine:
Calculate the flux of a point charge Q at the origin through a cube centered through the origin by both direct integration and Gauss's Law (essentially prove Gauss's Law for a point charge). Now I got the answer of Q/ε0 via direct integration alright. When I go to use Gauss's Law in Cartesian coordiantes I keep getting zero, however if I "surround" the cube with an imaginary spherical surface and take the flux through that in Spherical I get the correct answer. I'm trying to reconcile the discrepancy and the only thing I can come up with is that I might have to incorporate the Dirac-Delta Function to account for the fact that I'm dealing with a point charge to do this in Cartesian. Is this accurate to assume?
I have that E(r)=(Q/4πε0)(r-3)(r)
Where r=xi+yj+zk
Every time I take the divergence of E in Cartesian and simplify, I end up getting zero.
I basically tried generalizing doing the partial derivative instead of doing a derivative for each coordinate. Let s be the coordinate that I'm differentiating with respect to (i.e. I'm looking at ∂Es/∂s) in figuring out the divergence (i.e. ∂Ex/∂x+∂Ey/∂y+∂Ez/∂z). I am taking the Es to be (Q/4πε0)*s*(s2+r2+t2)-3/2where r and t are the other coordinates which are not being taken a derivative for. For ∂Es I keep getting (Q/4πε0)*(s2+r2+t2)-5/2*(r2+t2-2s2). When I apply this to each coordinate choice (s=x,s=y,s=z) and try to take the sum to get the divergence, I keep getting zero.
Answers and Replies
Philip Wood
75
Gauss's Law is a physical law, whereas Gauss's theorem is a mathematical truth. It seems to me that you're trying to use Gauss's theorem instead of Gauss's Law. Using Gauss's Law it is immediately obvious that the flux though the walls of the cube is [itex]Q/\epsilon_0[/itex], because the law says that this is the flux through any closed surface surrounding charge Q.
The more difficult bit is surely the direct integration, which I take to mean the evaluation of the integral, over the 6 faces of the cube, of E.dS. [Clearly we need only do the integration over one face, and then multiply the answer by 6. I chose a y-z face, divided it into strips, running in the z direction, integrated over one such strip (width dy), then integrated up the flux through each strip. I had to cheat and use the wonderful Wolfram online integrator for the second integration.] But you've already done the direct integration?
Addendum: The post (below) of vanhees71 shows beautifully how Gauss's law can be established using Coulomb's law and Gauss's theorem, when we have one or more 'point' charge(s) inside the closed surface.
vanhees71
Insights Author
2019 Award
15,059
6,540
To understand the difficulties with taking the divergence and then doing the volume integral, let's see, what's the physical situation that is described. We have given the electric field of a point charge sitting at the origin (in SI units), which is of course just the Coulomb field
[tex]\vec{E}(\vec{x})=\frac{Q}{4 \pi \epsilon_0} \frac{\vec{x}}{r^3}, \quad r=|\vec{x}|.[/tex]
To understand the problem, it's easier to go back to the fundamental equations, which are Maxwell's equations in differential form. Here, we need Gauß's Law (a fundamental physical law on electromagnetic fields, and one of Maxwell's fundamental equations), which says that the source of electric fields is the charge distribution (modulo an artificial factor from the choice of SI units):
[tex]\vec{\nabla} \cdot \vec{E}=\frac{1}{\epsilon_0} \rho.[/tex]
Now using Gauß's Theorem (a mathematical theorem) you can integrate this over an arbitrary volume
[tex]\int_{V} \mathrm{d}^3 \vec{x} \vec{\nabla} \cdot \vec{E}=\int_{\partial V} \mathrm{d}^2 \vec{F} \cdot \vec{E}.[/tex]
On the right-hand side [itex]\partial V[/itex] is the boundary surface of the volume oriented such that all surface-normal elements point out of the volume.
On the other hand, according to Gauß's Law, this integral is the charge inside the volume divided by the artificial unit-conversion factor, which leads to
[tex]\int_{\partial V} \mathrm{d}^3 \vec{F} \cdot \vec{E}=\frac{Q_V}{\epsilon_0}.[/tex]
Now, on the first glance all this holds for charge distributions which are continuous functions [itex]\rho(\vec{x}).[/itex] The point charge, is a somewhat strange thing for a classical field theory. To deal with such strange situations the physicists (Sommerfeld and later Dirac, after whom the concept is named) invented generalized functions (distributions). Mathematicians made this a rigorous subject later and invented functional analysis, which is the backbone of all modern physics (quantum theory) nowadays.
The point charge is a typical example. From a classical point of view it's a singularity, which you can smoothen out first by assuming it's a charge distributed somehow over a (small) finite spatial volume. To make things easy, you can assume it's a little spherical ball of radius [itex]R[/itex] centered at the origin filled homogeneously with the charge [itex]Q[/itex]. Then charge distribution then is
[tex]\rho(\vec{x})=\begin{cases}
\frac{Q}{V}=\frac{3Q}{4 \pi R^3} & \text{for} \quad |\vec{x}| \leq R \\
0, & \text{for} \quad |\vec{x}|> 0.\end{cases}
[/tex]
You can easily solve the electrostatics problem by integrating the spherically symmetric Poisson equation for the electrostatic potential. Here, we only need the solution for [itex]|\vec{x}|>R[/itex] since anyway, we want to let [itex]R \rightarrow 0[/itex] finally. Of course, outside of the sphere the field is just the Coulomb field written down above. Inside the sphere there is no singularity anymore, but a radial field proportional to the distance from the origin.
Now you can easily use Gauß's Theorem to calculate the elecric flux through any surface you are given, because there are no more singularities. Now take your cube. In the above consideration you can choose the radius of the artificial sphere over which you've "smeared out" your point charge as small as you like. So make it as small that it's totally contained in your cube. Now you don't need to do the calculation explicitly anymore, because what you get is clearly the charge inside the cube, which is [itex]Q[/itex], i.e, you get
[tex]\int_{\partial V} \mathrm{d} \vec{F} \cdot \vec{E}=\frac{Q}{\epsilon_0}.[/tex]
As you see, it doesn't really matter how your surface [itex]\partial V[/itex] is shaped, as long as the little sphere is completely inside this surface.
Now you can as well let the radius of your "smearing sphere" to 0. Nothing happens to your integral, because it doesn't depend on [itex]R[/itex] (for sufficiently small [itex]R[/itex]). The important thing is, what happens to the charge densitity and the field! The field will be the Coulomb field over all space, but of course it has a singularity at the origin, where the point charge sits. The corresponding charge distribution becomes 0 everywhere except at the origin, where it becomes infinite, but it becomes infinite in a specific way! The infinity is such, that nothing happens to your integral, i.e., the integral over this singular charge distribution over any volume containing the origin, must be the total charge, [itex]Q[/itex]! This is a way to introduce the Dirac-[itex]\delta[/itex] distribution. For our point charge we have by this definition
[tex]\rho(\vec{x})=Q \delta^{(3)}(\vec{x}).[/tex]
Then Gauß's Law also implies that the divergence of the Coulomb field is 0 everywhere except at the origin, where it has a "[itex]\delta[/itex] singularity":
[tex]\vec{\nabla} \cdot \frac{\vec{x}}{4 \pi r^3}= \delta^{(3)}(\vec{x}).[/tex]
This explains your difficulty using Gauß's theorem to evaluate the flux via the volume integral: You forgot the [itex]\delta[/itex] distribution, i.e., the pointlike source of the Coulomb field! The singularity of the Coulomb field is such that the above formula of it's divergence holds: It's 0 everywhere except at the origin, where the field and the charge distribution have singularities which are compatible in a way such that Gauß's Law still holds for point charges.
The complicated introduction of the [itex]\delta[/itex] distribution is very useful, although it's a bit unfamiliar in the beginning. When you get used to it, it helps a big deal to handle point charges and other useful singularities in electromagnetism. The most important mathematical concept in connection with this is the Green's-function technique to solve the various linear partial differential equations, you encounter in classical electromagnetism frequently. One example is the Green's function of the Laplace operator
[tex]\Delta G(\vec{x},\vec{x}')=-\delta^{(3)}(\vec{x}-\vec{x}').[/tex]
This (formally) gives you the electric potential for a point charge of value [itex]\epsilon_0[/itex], which immediately tells you its solution via the Coulomb potential:
[tex]G(\vec{x},\vec{x}')=\frac{1}{4 \pi |\vec{x}-\vec{x}'|}.[/tex]
The important thing is that now you can calculate the electric potential for any charge distribution by integrating it with help of this Green's function
[tex]\Phi(\vec{x})=\frac{1}{\epsilon_0} \int_{\mathbb{R}^3} \mathrm{d}^3 \vec{x}' \frac{\rho(\vec{x}')}{4 \pi |\vec{x}-\vec{x}'|}.[/tex]
Thank you, the both of you. I included the Dirac-Delta part in my new attempt. It took me a LONG time to figure out how to work it, but I did.
Related Threads on Gauss's Law in Cartesian Help
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
22K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
