Gauss's Law in Matter: What is It?
In summary, the Gauss's law in a dielectric material is given by: the electric displacement field is proportional to the amount of charge within that closed surface.
Apteronotus
202
Hi,
The Poisson equation (or Gauss Law) in a vacuum is given by
[itex]\nabla^2\phi=-\frac{\rho}{\epsilon_0}[/itex]
where [itex]\rho \mbox{ and } \epsilon_0[/itex] are the charge density and vacuum permittivity or (electric constant of space).
My question is what is the Gauss's Law in a dielectric material? Do we simply replace the vacuum permittivity by the permittivity of the material?
ie.
[itex]\nabla^2\phi=\frac{\rho}{\epsilon_r}[/itex]
where above [itex]\epsilon_r[/itex] is the relative permittivity (or permittivity of the dielectric material).
Thanks,
Hi,
I would check some books for follow up.
How is it Gauss's law in vacuum? What is then carrying the charge?
Beyond that I think it matters whether you're talking linear dielectric or non-linear dielectric.
For a linear dielectric if you state it using the fields use the displacement field instead of the electric field and then it accounts for the free charge with the new permittivity.
From what I've read, Guass's law is usually given in its integral form, saying that "the amount of electric flux through a surface is proportional to the amount of charge within that closed surface".
Then the differential form is derived using divergence theorem relating the divergence of the electric field to the surface charge density [itex]\rho[/itex].
So in short everything seems to be in a vacuum. But how do these equations compare if say we have a linear, homogeneous, isotropic material?
Poissons equation is bit different from Gauss Law(In addition to it,Poissons eqn requires that the field is derivable from a scalar potential)
Coming to the point,In matter, Gauss Law is expressed as the surface Integral of the the displacement vecotr being equal to the the total enclosed free charge.
If the matter is linear and Homogeneous,it can be written in form of Poissons equation with source Free charge divided by epsilon.
The equation you proposed is dimensionally incorrect,as you can see.
Thank you all for your responses. jtbell the resource you linked to is very informative, thank you.
Following equation 813, would it be correct to deduce
[itex]\nabla^2\phi=-\frac{\rho_{f}}{\epsilon \epsilon_0}[/itex]
Yes,for Linear and Homogeneous dielectrics
and isotropic
In a dielectric material, Gauss's Law holds for the electric displacement field [itex]\mathbf{D}[/itex]:
[tex]
\nabla \cdot \mathbf{D} = \rho_f
[/tex]
where [itex]\rho_f[/itex] is the free charge density.
The dielectric is modeled by a relative dielectric constant, which meaning (for an isotropic medium) is:
[tex]
\mathbf{D} = \varepsilon_0 \, \varepsilon_r \, \mathbf{E}
[/tex]
The electric field, being irrotational, is still derivable from the electrostatic potential:
[tex]
\mathbf{E} = -\nabla \, \phi
[/tex]
1. What is Gauss's Law in Matter?
Gauss's Law in Matter is a fundamental law in electromagnetism that relates the electric flux through a closed surface to the net charge enclosed within the surface. It states that the electric flux through any closed surface is equal to the net charge enclosed by that surface divided by the permittivity of the medium.
2. How is Gauss's Law in Matter different from Gauss's Law in free space?
Gauss's Law in free space only applies to situations where there are no charges or matter present. However, Gauss's Law in Matter takes into account the presence of charges and matter, and the permittivity of the medium. This allows for a more accurate calculation of electric fields in materials.
3. What is the significance of Gauss's Law in Matter?
Gauss's Law in Matter is a fundamental law in electromagnetism and is used to understand and calculate electric fields in materials. It also helps in determining the distribution of charges within a material and can be used to solve a variety of practical problems in engineering and physics.
4. How is Gauss's Law in Matter applied in real-world situations?
Gauss's Law in Matter is applied in various real-world situations, such as in the design of electronic circuits, the calculation of electric fields in materials used in technology and industry, and in the study of atmospheric electricity and lightning. It is also an important concept in understanding the behavior of materials in the presence of electric fields.
5. Are there any limitations to Gauss's Law in Matter?
One limitation of Gauss's Law in Matter is that it assumes the material is linear, isotropic, and homogeneous. This means that the material's properties remain constant throughout and are not affected by external factors. In reality, some materials may exhibit non-linear behavior, anisotropy, and inhomogeneity, which can affect the accuracy of calculations using Gauss's Law in Matter.
  • Electromagnetism
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Classical Physics
