Solve Gauss's Law Problems: q, E, ΦE
In summary, a point charge at the center of a spherical Gaussian surface does not change the flux of ΦE when replaced with a cube of the same volume, but will change if the charge is moved off center within the original sphere. For a point charge at the center of a cube, the flux through each face is q/6ε. However, if the charge is placed at a corner of the cube, the flux through each face becomes q/8ε.
zorro
1,384
1) A point charge is placed at the centre of a spherical Gaussian surface. Is ΦE changed,
a) if the surface is replaced by a cube of the same volume?
b) if the charge is moved off centre in the original sphere, still remaining inside?
2) A point charge q is placed at the centre of a cube of edge a. What is the flux through each of the cube faces? A point charge q is placed at one corner of a cube of edge a. What is the flux through each of the cube faces?
The attempt at solution
1) a) E remains same as the charge is not changed in magnitude. Surface area of the cube is different, Φ=Edscosθ
So ds being different ΦE will change.
b) If we consider the sphere to be our Gaussian surface, the charge enclosed does not change in its magnitude. Hence no change in ΦE
2) ΦE = q/6ε for both the cases as E,ds,q all remain same in both cases.
1) a) and 2) second part is wrong. Please explain.
1(a), total flux from a point charge does not depend on the nature of the Gaussian surface. Σdφ = ΣE*ds*cosθ. Here E is not constant at the different points on the surface of the cube.
2. who many small identical cubes can be formed in a larger cube.
1. Σdφ = ΣE*ds*cosθ. Here E is not constant at the different points on the surface of the cube.
1. Do you mean E and ds adjust themselves in such a way that flux remains same?
2. I did not get you.
1) Yes. Flux is a measure as how much stuff is coming out, how much is diverging. The surface has changed, but the amount of stuff coming out is the same.
2) You would be right for the first part. For the second part you would find life much easier if you made a larger cube out of the smaller cube so that the charge could be in the center again. Then readjust to get the flux coming out of the small cube. The charge is no longer "inside" the cube, so you'd expect a flux change.
I don't understand what is the problem if the charge doesnot remain in the centre? As you said flux is a measure of the 'stuff' coming out - q does not change in magnitude- so 'stuff' coming out doesnot change.
Why is the charge no longer inside? Don't you think the corner of your room is not inside your room?
By your analogy, if I went to the point corner of the room, I'd have to go to the wood; no longer inside the room. Geometrically, you can't be inside a figure if you are at an edge that is defining a figure.
The point charge emits electric field in all direction.
You can imagine a charge on the corner of a cube as a charge at the center of a large cube made of eight identical cubs. The cube contain six surfaces, each having four squares. Total squares are 24. Total flux is divided into 24 equal parts. Three surfaces of each cube produces the flux. So φ = 3*q/24*εο = q/8εο.
1. What is Gauss's Law and how does it relate to electric fields?
Gauss's Law is a fundamental law in electromagnetism that relates the electric field to the distribution of electric charge. It states that the electric flux through a closed surface is equal to the total charge enclosed by that surface divided by the permittivity of free space.
2. How do I determine the electric field using Gauss's Law?
To determine the electric field using Gauss's Law, you first need to choose a closed surface that encloses the charge distribution. Then, you can use the equation ΦE = q/ε0, where ΦE is the electric flux, q is the total charge enclosed, and ε0 is the permittivity of free space. Rearranging this equation, you can solve for the electric field (E = ΦE * ε0 / q).
3. Can Gauss's Law be used to solve problems with both point charges and continuous charge distributions?
Yes, Gauss's Law can be used to solve problems with both point charges and continuous charge distributions. For point charges, you can use a Gaussian surface in the shape of a sphere or a cylinder. For continuous charge distributions, you can use a Gaussian surface in the shape of a cylinder or a box.
4. What is the unit of electric flux and how is it related to the unit of electric field?
The unit of electric flux is N·m²/C (newton-meter squared per coulomb). This is equivalent to V·m (volt-meter) or N/C (newton per coulomb), which are the units of electric field. This shows the direct relationship between electric flux and electric field.
5. Are there any limitations to using Gauss's Law to solve problems?
Yes, there are some limitations to using Gauss's Law. It can only be used for problems with static electric fields, meaning the charge distribution does not change over time. It also assumes that the permittivity of free space is constant throughout the region of interest. Additionally, it is only applicable to problems with closed surfaces, so it cannot be used for open systems or problems with non-uniform charge distributions.
