Can the GCD of Polynomials in a Field Always Be Reduced to 1?
In summary, the gcd of two polynomials, p(x) and q(x), can be represented as gcd(p(x),q(x))=p(x)m(x) + q(x)n(x) for some n(x) and m(x) in F[x]. To show that gcd(n(x),m(x))=1 for a fixed gcd(p(x),q(x)), you can let D(x)=gcd(p(x),q(x)) and use the fact that D(x)|q(x) and D(x)|p(x), leading to q(x)=D(x)k(x) and p(x)=D(x)s(x). By substituting these expressions, you get D(x)=D(x)k(x)m(x)+D(x)s(x)n
alexfresno
We know that the gcd of two polynomials can be written as
gcd(p(x),q(x))=p(x)m(x) + q(x)n(x) for some n(x) and m(x) in F[x] F a fieldI want to show gcd(n(x),m(x))=1 for a fixed gcd(p(x),q(x))
Well, what I tried was to let D(x)=gcd(p(x),q(x))
then D(x)|q(x) and D(x)|p(x). Which implies that q(x)=D(x)k(x) and p(x)=D(x)s(x) for some k(x),s(x) in F[x].
Then i got D(x)=D(x)k(x)m(x)+D(x)s(x)n(x) by substitution
Can I divide both sides by D(x) since we are in a Field? If i can...
then won't 1=k(x)m(x)+s(x)n(x) imply gcd(m(x),n(x))=1?? or there is a stronger proof?
I think your proof is correct!
What is the GCD of polynomials in a field?
The GCD (Greatest Common Divisor) of polynomials in a field is a polynomial of highest degree that divides evenly into all given polynomials. It is also referred to as the highest common factor.
How is the GCD of polynomials in a field calculated?
The GCD of polynomials in a field can be calculated using the Euclidean algorithm, which involves dividing the polynomials and finding the remainder until a polynomial with a degree of 0 is reached. The last non-zero remainder is the GCD.
What is the significance of the GCD of polynomials in a field?
The GCD of polynomials in a field is important because it allows for simplification and factorization of polynomials. It also helps in solving polynomial equations and finding common factors.
Can the GCD of polynomials in a field be equal to 1?
Yes, the GCD of polynomials in a field can be equal to 1 if the given polynomials have no common factors. This means that the polynomials are relatively prime.
Can the GCD of polynomials in a field be negative?
No, the GCD of polynomials in a field is always a positive polynomial. This is because the GCD is defined as the highest common factor, and by definition, a factor cannot be negative.
