What is the GCD of A and B on a Union Magma?
In summary, the magma S has the power set P(S), and two elements A and B are in P(S). The GCD of A and B is X, which is a subset of A and B.
1MileCrash
1,342
41
Consider the following magma, S is not empty; P(S) is the power set.
(P(S), U)
Now, let A and B be in P(S).
What is the GCD of A and B?
If I choose a common divisor of A and B under unions, call it X, I get that X is a subset of A and B as the only requirement.
The only way I can interpret "GCD" is that X is the largest such set. Then X = (A intersect B.)
Agree?
(P(S), U)
Agree?
You should give a few more definitions here. But it sounds plausible if 'divisor' means set containment and 'greater' is also defined in terms of set containment.
I thought "magma" had something to do with volcanos!
The operation on the magma is union, so X is a divisor of A if there exists some set L in P(S) so that (X U L) = A.
I think this is equivalent to set containment (X is a subset of A).
I took "greater" to mean larger cardinality in this case. I reckon that the largest set that is a subset of A and B is (A intersect B), and that's why I think it is the GCD of A and B.
Ah ok, I see. So yes, L 'divides' A is equivalent to L is a subset of A. Defining "greater" in terms of cardinality can get you into some trouble with infinite sets. If the intersection of A and B is infinite, there may be many subsets with the same cardinality contained in it.
I had to look it up too. A "magma" is a set with a binary operation and that's it. No other properties necessary. Bourbaki invented the terminology.
I didn't think of that.. perhaps instead of cardinality, I could say that the greatest common divisor is a superset of all other common divisors?
EDIT: Sorry about the terminology confusion, it is what my professors calls them, yes, a magma (M,*) is a set M with a binary operation *: M -> M.
When we talk about divisibility in a magma (M,*), * becomes analogous to multiplication and M becomes analagous to Z, regardless of what they actually are.
Or just define A is 'greater' than B to mean B is a subset of A. Which amounts to the same thing.
Thank you for the assistance.
1. What is the GCD of A & B on Union Magma?
The GCD (Greatest Common Divisor) of A and B on Union Magma is the largest positive integer that divides both A and B without leaving any remainder.
2. How is the GCD of A & B calculated on Union Magma?
The GCD of A and B on Union Magma is calculated using the Euclidean algorithm, which involves finding the remainder when A is divided by B and then using this remainder as the new value for B in the next iteration. This process continues until the remainder is 0, and the last non-zero remainder is the GCD of A and B.
3. Can the GCD of A & B on Union Magma be negative?
No, the GCD of A and B on Union Magma is always a positive integer since it represents the largest positive integer that divides both A and B.
4. What is the significance of the GCD of A & B on Union Magma?
The GCD of A and B on Union Magma is a useful concept in number theory and has many applications in mathematics, including simplifying fractions, finding common factors, and solving equations involving fractions.
5. Is the GCD of A & B on Union Magma commutative?
Yes, the GCD of A and B on Union Magma is commutative, which means that the order in which A and B are given does not affect the result. This property is also known as the "gcd property."
  • Linear and Abstract Algebra
