Can a 250 cc Honda Engine Be Integrated into a Car with a Button Gear Shift?
  • Thread starter nikhilesh
  • Tags
    Gear Shift
In summary, the conversation discusses the integration of a 250cc Honda engine into a car and the difficulty of changing gears with a foot pedal. The idea of using a small motor or solenoid to shift gears is brought up, but the suggestion of a mechanical linkage or cable system is favored. The use of a solenoid is seen as unnecessary and potentially adding extra weight and complexity.
nikhilesh
I've a gearbox from a 250 cc Honda engine. The pattern in one down and four up. This engine will be integrated into a car, so the changing of gears will be difficult with the foot pedal. wouldn't it ? :) . So i decided to integrate a small motor to the gear shift pedal so that it can change gears. Is this feasible?
Will it work?
any answers?
what about hydraulic shifting? Like using a paintball CO2 bottle or those 12 gram CO2 cartridges.
Is weight a concern? Would the motor and its power supply be lighter than a CO2 shifting system?
It shouldn't be hard to add a linkage from the gearbox to a regular floor-mounted stick. A cable system would probably be easiest.
SELENOID A DOUBLE should work to shift up and down
trick is to match it to the effort required
not too strong or weak
but there are a lot of car [12v] selenoids in use
a trip to a junk yard should get you a bunch
what exactly is a selenoid? what's it used for in a car?
and the idea behind the motor, is to make the gear shift with a button or paddle... while still using the clutch with the other hand... all this on the steering wheel
a selenoid is a el-trick magnet that moves something
a double throw selenoid moves in and out depending on current direction
most are switches but some move things like on a starter or a air flow flap
You may have better luck searching for a 'selenoid' if you spell it 'solenoid'.
Personally, I think this sounds like the kind of application where you'd be much better off with a mechanical linkage of some sort. Danger's suggestion of cables would be worth looking at, or (depending on packaging constraints) a simple system of pivoting rods.
This is an excellent way to do it. I recently saw an internet video that had just this setup in a dune buggy with a rear-mounted 1200cc crotch-rocket engine in it. There was a "shifter" next to the driver, forward was shift up and backward was shift down.
Using a solenoid is extra weight and extra trouble. I too would go for the mechanical shift linkage approach.
1. How does a gear shift with a button work?
A gear shift with a button uses an electronic mechanism to change gears instead of a traditional manual gear shifter. The driver simply presses a button to shift to a different gear.
2. What are the benefits of a gear shift with a button?
Some benefits of a gear shift with a button include faster and smoother gear changes, improved fuel efficiency, and less driver fatigue.
3. Are there any drawbacks to using a gear shift with a button?
One potential drawback is that it may take some time for drivers to get used to the electronic shifting system, which can be different from traditional manual shifting. Additionally, a failure in the electronic system could result in an inability to shift gears.
4. How does a gear shift with a button affect driving experience?
A gear shift with a button can improve the overall driving experience by providing more precise and efficient gear changes. It can also make driving more convenient and less physically demanding for the driver.
5. Is a gear shift with a button available in all vehicles?
Currently, gear shifts with a button are mostly found in high-end luxury vehicles. However, as technology advances and becomes more affordable, it is possible that more vehicles will offer this feature in the future.
  • Mechanical Engineering
24K
10K
