Homework Help: Gear train design with idler gear
  1. Oct 1, 2009 #1
    Construct a gear train using at least three idler gears of any tooth size.the driver gear had 15 teeth,Pd of 16 n 4625rpm clockwise.driven gear must able to pull up a weight 18kN with velocity 0.7-1.3 m/s. The gear is made of small n large gear,connected together.the smaller is having 20 teeth n Pd of 15.bigger has radius of 100mm. The distance between driver m driven must b less than 1000mm.
    2. Relevant equations
    Gear ratio=n1/n2
    3. The attempt at a solution
    gear ratio=20/15
    = 1.8
Draft saved Draft deleted
