General motion of a particle
  • Thread starter jiboom
a particle moves in the xy plane such that at a time t it is at a point (x,y) where
x=2cos(at)
y=2sin(at)
prove particle moves in a circular path with constant angular velocity. prove that the acceleration of the particle at time t is in the direction of the radius from the particle to the centre of its path.
so i have
R=[2cos(at),2sin(at)]
V=[-2asin(at),2acos(at)]
A=[-2a^2cos(at),-2a^2sin(at)]
not sure how to show angular is constant.
i can take |V| and that s constant but im not using angular velocity.
for the second part:
if if i take direction of A= (d2y/dt2)/(d2x/dt2)=tan(at) where d2y/dt2 is second derivative of y wrt t
does this answer the question as motion is circle centre (o,0) so any radius will have tan (at) as its gradient?
Answers and Replies
tiny-tim
25,832
251
hi jiboom! :smile:
(try using the X2 button just above the Reply box :wink:)
that's fine :smile: … now use v = rω (and r is constant) :wink:
erm :redface:
isn't it obvious that A is parallel to (x,y)? :wink:
now you point it out, yes it is:)
i was going to use v = rω but as i am taking |v| am i not just getting angular speed not velocity?
think im being thick.
is it that as angular velocity only depends on the angle we have |ω|=ω
just as v=|v| for 1-d motion
sorry but im now confused again.
the question actually says
x=2cosωt
y=2sin ωt
so
V=V=[-2ωsin(ωt),2ωcos(ωt)]
so |V|=2ω
so using v=rω only gives me r=2????
HallsofIvy
41,833
956
x=2cosωt
y=2sin ωt
so
so |V|=2ω
No, you knew from the original position vector that the mass was moving in a circle with radius 2: if [itex]x=2 cos(\omega t)[/itex]and [itex]y= 2 sin(\omega t)[/itex], then [itex]x^2+ y^2= 4 cos^2(\omega t)+ 4 sin^2(\omega t)= 4[/itex].
The calculation you have done is the derivation of [itex]v= r\omega[/itex]!
so what do i need to say to justify angualr velocity is constant?
tiny-tim
25,832
251
hi jiboom! :smile:
(been out for the evening o:))
yup, x=2cosωt y=2sin ωt means r = 2 and angular speed = ω !
again, it's obvious!
go to sleep on it :zzz:, and it'll all be obvious in the morning!
hi jiboom! :smile:
lol. wont be sleeping til i get this.
i dont have much here to play with.
v=rω
now is ω angular velocity or angular speed?
the v i have is not angular velocity and not constant
r is 2
now in your first post you said to use v=rω but then i just get r=2 so that does not show
angular velocity = constant
think its going to be long night unless i get a big nudge here,its not obvious to me due to a lack of understanding about velocity v speed |v| angular velocity ω and angular speed | ω|
tiny-tim
25,832
251
v=rω
what's the difference??
we're in 2D, so they're the same
r is 2
but you know that v is constant (from the formula), so it does :smile:
… its not obvious to me due to a lack of understanding about velocity v speed |v| angular velocity ω and angular speed | ω|
i think you're over-thinking this
v is velocity, v is speed, v = |v|
ω is angular velocity, ω is angular speed, ω = |ω|
v = rω
v = ω x r :wink:
i see what you are saying but im thinking along these lines:
ω
then how can i then say |v| is constant? |v| is 2ω so is only constant if ω is but that is what im trying to show
and i dont understand
v = ω x r
lhs is a vector,but rhs is vector product of 2 scalars ?
tiny-tim has gone off-line. can you help explain what they were getting at?
tiny-tim
25,832
251
hi jiboom! :smile:
(just got up :zzz:)
ω
v = |v| is constant because the coordinate formula for v shows it is
v = ω x r
no, ω and r are both vectors, the rhs is a vector product of two vectors
(technically, ω is a pseudovector :wink:)
v = ω x r is the definition of the angular velocity vector for a rigid body
hi jiboom! :smile:
(just got up :zzz:)
im afraid im totally lost here.
v = |v| is equal to 2ω so how are you saying this is constant?
im trying to show ω is constant which you seem to be saying,forgive me if im misunderstanding, is equal to ω
so i dont see how the constancy of v follows without assuming what im trying to show, ie ω is constant.
v = ω x r: still dont see what the vector is for ω. i thought the r was radius,but i now think its the postion vector of the particle.
tiny-tim
25,832
251
hi jiboom! :smile:
… so i dont see how the constancy of v follows without assuming what im trying to show, ie ω is constant.
it follows from the following coordinate equations …
… what is |v| ? :smile:
ω is the vector of magnitude ω pointing along the axis of rotation
and yes, r is the position vector of the particle
important
v = ω x r is an equation you need to be completely familiar and happy with
you need to study it in your books or wikipedia or other internet site (google "angular velocity" and "rigid body") until you are :wink:
hi jiboom! :smile:
important
as i say |v|=2ω, but if ω is the angular velocity then i cant say this is constant without assuming what i want to prove.
i should say,i have changed that a in my op to ω as that is the letter the question uses.
anyone ?
hi jiboom! :smile:
hi. dont give up on me just yet :)
i do appreciate your help and just need one last shove to get there.
all i need convincing off now is that the omega=angular speed =|v| is constant.
does this follow from the question? if this is so,then for sure i am happy |v|=constant => angular velocity is.
tiny-tim
25,832
251
in your original post, you wrote …
so |V| = … ? :smile:
hi,thanks for coming back.
forget the a,the letter used in the question was omega.
i know what |V| is,it is just 2omega
but....
if this omega (a in my original post) is the angular speed i cant say |v| is constant UNLESS i know omega in the question is constant?
maybe i should be clearer, when in question i have
R=(2cos wt,2sinwt)
as this w is not said to be constant in the question i could have w=w(t) and should really have
V=(-2sin(wt)(d(wt)/dt),2cos(wt)(d(wt)/dt)
maybe an easier question would be to clear up what the w is in the question
so from
R=(2coswt,2sinwt)
is the w the same as |w| the angular speed?
if so,is it just to be assumed its a number and not a function of some variable such as time as it's not writtem w(t)?
tiny-tim
25,832
251
R=(2cos wt,2sinwt)
oh i see!!! :tongue2:
no, i think it's safe to assume that the ω in the question is constant (in exactly the same way as you would if it was a instead of ω :smile:) …
it never occurred to me to think otherwise!​
stop imagining that the questions are more difficult than they really are! :rolleyes:
yes!! :smile:
yes!! :smile:
great,thanks for your time with this.
Related Threads on General motion of a particle
  • Last Post
