General Relativity: Is There No Universal Frame or No Way to Tell?
In summary, General Relativity claims that you can' say any reference frame is better than another frame, including frames in which Newton's Laws don't hold. However, heliocentrism is still preferred due to its simplicity.
Afterthought
29
I've heard that unlike Special Relativity, General Relativity claims that you can' say any reference frame is better than another frame, including frames in which Newton's Laws don't hold. I've seen debates about this specifically in the context of geo/helio-centrism. From what I understand, neither is more true than the other in the context of GR, but heliocentrism is still preferred due to its simplicity. What I want to know is: Does GR claim that there is no universal inertial frame, or that there's no way of telling if there is? Meaning, if the latter is true, then maybe one exists but we have no way of telling.
This is probably a silly question, since I really don't know much about GR (I've learned SR though), so please correct me if I'm thinking about this incorrectly.
That is not a disagreement between special and general relativity. They both agree that one frame is not better than another, and it doesn't matter whether Newton's laws hold in the frame (the frame is inertial) or not. They also both agree that it is nearly always easier to do your calculations in an inertial frame.
They differ in that in special relativity it is possible to find global inertial frames, ones that cover all of spacetime, whereas in general relativity it is not. You can only have inertial frames when spacetime is flat, which is the case for all spacetime in SR so there'sno problem finding a global inertial spacetime. But GR is also applied to curved spacetimes, and there a frame can only be inertial if it covers a small enough region of spacetime that we can ignore the curvature and treat that small patch of spacetime as if it were flat.
Likes vanhees71 and Laurie K
If there is no way of telling then it doesn't matter either way.
1) There's no way of telling some things in quantum mechanics (eg. uncertainty principle), but people still argue about what reality is like. Or did you mean something else by that?
2) Does GR really say that there's no way of telling? So if someone claims that they found a way to distinguish a universal frame from other frames, would that necessarily conflict with GR?
Yes, and also with abundant experimental evidence. For example, gravitational lensing couldn't happen if there were a single inertial frame that covered all the paths that the various light beams are taking.
(I do note that in the post I just quoted, you said "distinguish a universal frame", while in your first post you asked about "a universal inertial frame". The answer I just gave assumes that you're still talking about the existence of a universal inertial frame, something that cannot exist in curved space time so must necessarily conflict with GR).
It says that there is no way to tell. And note that there are different definitions of "inertial frame"; I suspect that your definition differs from that of those who replied before me.
Uncertainty principle does not say that "there's no way of telling some things".
You can ask anyone with at least two young children: the fact that people argue about something does not imply that the thing they are arguing about matters.
Yes, such an experiment would indeed conflict with GR. However, since GR is known to be valid over a fairly broad domain of applicability, any theory that explained such an experiment would still have to reduce to GR in the appropriate limit.
1. What is general relativity?
General relativity is a theory of gravity that was developed by Albert Einstein in the early 20th century. It describes how gravity works by showing how massive objects cause space and time to curve, and how this curvature affects the motion of other objects.
2. What is the concept of a universal frame in general relativity?
In general relativity, there is no concept of a universal frame of reference. This means that there is no single point of reference that is considered to be completely motionless and unaffected by gravity. Instead, every observer's frame of reference is equally valid and can be used to understand the motion and interactions of objects.
3. Is there no way to measure the absolute motion of objects in general relativity?
No, there is no way to measure the absolute motion of objects in general relativity. This is because motion is always relative to a particular frame of reference, and there is no universal frame of reference in this theory.
4. How does general relativity explain the phenomenon of time dilation?
General relativity explains time dilation as a result of the curvature of space-time. The closer an object is to a massive object, the more it is affected by the curvature of space-time, causing time to pass more slowly for that object compared to a more distant observer.
5. Are there any experiments that have confirmed the predictions of general relativity?
Yes, there have been numerous experiments that have confirmed the predictions of general relativity. One of the most famous examples is the observation of gravitational lensing, where the light from distant objects is bent by the curvature of space-time around massive objects, as predicted by general relativity.
