Genetics: Is Insect Resistance Trait Dominant or Recessive?
  • Thread starter devinthedudeuwm
  • Tags
    Genetics
In summary, after several generations of genetically engineering a tomato plant to be resistant to an insect pest, a true-breeding line of insect resistant tomatoes has been obtained. The insect-resistance trait is likely to be recessive since it takes multiple generations of breeding for all offspring to exhibit the resistance trait. This is supported by the fact that it is difficult to develop a line of true-breeding plants that produce only resistant plants if the trait is dominant.
devinthedudeuwm
You have genetically engineered a tomato plant to be resistant to an insect pest by introducing a gene into tomato seeds that codes for a protein that is poison to the insect, but harmless to humans. After several generations you have obtained a true-breeding line of insect resistant tomatoes.
Is the insect-resistance trait likely to be dominant or recessive?
I would think recessive only because it needs to go several generations before it becomes true-breeding. Can someone please give me a good explanation?
Resistance has generally been found to be a recessive or partially recessive trait, anyone else?
Think about it...we will represent the allele with r, and the regular non-resistance with R. The first generation would be RR, since they don't have the allele. You introduce the allele into 2 plants and have them reproduce:
r R
r rr Rr
R Rr RR
You breed two of these together, seeing from experimentation that one is resistant but most are not:
r r
r rr rr
R Rr Rr
Now you find that two are resistant (the two homozygous recessive) and breed these. Now, you notice that all of the offspring are resistant. If the allele was dominant, it would be nearly impossible to develop a line of true breeding plants that produce only resistant plants. It is impossible to tell whether a plant that represents the trait is homozygous or heterozygous. Impossible? Of course not...but probability points to it being recessive.
1. What is insect resistance trait in genetics?
Insect resistance trait refers to a genetic characteristic in insects that makes them resistant to certain insecticides or chemicals that are used to control their population. This trait is inherited from the parent insects and can be either dominant or recessive.
2. How is insect resistance trait inherited?
Insect resistance trait can be inherited through both dominant and recessive genes. If the trait is dominant, it means that only one copy of the gene is needed for the insect to be resistant to the chemical. If the trait is recessive, both copies of the gene must be present for the insect to be resistant.
3. Is insect resistance trait more commonly dominant or recessive?
Insect resistance trait can be either dominant or recessive, depending on the specific insect species and the type of chemical or insecticide being used. Some insects may have a dominant resistance trait, while others may have a recessive trait.
4. Can insect resistance trait be passed down to offspring?
Yes, insect resistance trait can be passed down to offspring through the process of inheritance. If one or both parents have the dominant or recessive resistance trait, their offspring may also inherit the trait.
5. Are there any other factors that can affect the expression of insect resistance trait?
Yes, there are other factors that can affect the expression of insect resistance trait, such as environmental conditions and the presence of other genetic traits. For example, certain environmental factors may decrease the effectiveness of the resistance trait, or the presence of other genetic traits may enhance or inhibit the expression of the resistance trait.
  • Biology and Medical
  • General Discussion
16K
