Geometric algebra
  • Thread starter scariari
Main Question or Discussion Point
can anyone explain how commutators act on tri-vectors (in orthonormal conditions)?
on bi-vectors i know that it ends up to be a bivector again,
but with tri-vectors it vanishes if its lineraly dependent.
what about the case if its not linearly dependent,
does that mean it remains a tri-vector?
how does a vector transform under a transformation generated by exponentiation of a trivector ?
a transformation is a rotation or reflection,
but who can explain the exponentiation?
Answers and Replies
Hint:
[tex]
\exp{(ix)}=\cos{(x)}+i\sin(x)
[/tex]
so using exp(ix)=cos(x)+ isin(x), multiplying it by the vector, this will result in a rotation, correct?
i have found examples for bi-vectors, but how does this change with tri-vectors?
for a bivector:
I^2=-1
K^2=1
exp(Ix)=cos(x)+I sin(x)
exp(Kx)=cos(hx)+K sin(hx)
cos (hx)=0.5(exp(x)+exp(-x)
sin(hx) = 0.5(exp(x)-exp(-x)
v'=exp(Kx)vexp(-Kx)
abs(v)=sin(hx)/cos(hx)=tan(hx)
is this a lorentz transformation?
also, i read that complex numbers represent vectors as points with the transformation...?
Yes, R+iI <-> (R,I).
Ah, now I think I understand what you mean.
Of course, you can't usually define the exponentiation of a vector. But you can define the eponentiation of a linear operator (matrix).
Like this: Let A be a matrix, then
[tex]
\exp{(A)}=\sum_{k=0}^\infty \frac{A^k}{k!}.
[/tex]
Let's say a transformation can be written in the form
[tex]
x' = \exp{(A)} \cdot x.
[/tex]
Now, if A = 1 + Gt with some parameter t, then G is called the generator of this transformation. For rotations, t is the angle.
if the commutator of a bi-vector [A,B] is found by AB-BA, is the commutator of a tri-vector then ABC-BCA-CAB?
Related Threads on Geometric algebra
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
