Geometric Sequence: T1=0.1024, T2=0.256, Middle Term=156.25
In summary: Wow. I need to wake up. I think I meant to say: if the middle term of a sequence is the nth term, then there are 2n - 1 terms in the sequence.
ThomasMagnus
138
A finite geometric sequence has t1 = 0.1024 and t2 = 0.256. How many terms does this sequence have if its middle term has a value of 156.25?
My Solution
Common Ratio: T2/T1=(.256)/(.1024)=2.5
What term # is the middle term?
tn=ar^n-1
a=0.1024
r=2.5
tn=156.25
(156.25)=(0.1024)(2.5)^n-1
1525=(2.5)^n-1
[Log(1525)/Log(2.5)]+1=n
n=8+1=9
n is the middle term so final term should be 2n. 18 terms in the sequence
From the way I have seen other people do this question, they get the answer "17 terms". Why am I 1 term off? Can you help me with what I am doing wrong. Or am I doing it correctly :)
Thanks!
Not so! Can a sequence with an even number of terms have a middle term?
For example, if I have a simple sequence of natural numbers where 3 is the 3rd and middle term:
1 2 3 ...
You're saying that there are 2n, or 6 terms in the sequence:
1 2 3 4 5 6
See the problem? If 3 is the middle term, then there are 2n - 1, or 5 terms in the sequence:
1 2 3 4 5
So there should be 17 terms in the sequence in your problem.
1 2 3 ...
1 2 3 4 5 6
1 2 3 4 5
I'm struggling to understand what you are saying.
"You're saying that there are 2n, or 6 terms in the sequence:
1 2 3 4 5 6"
Isn't there six terms in this sequence?Thanks :)
1 2 3 4 5 6"
Yes, but I consider this sequence to have no "middle term", because there are an even number of terms. If you have a 5 term sequence (2n - 1):
1 2 3 4 5
... then 3 would be the middle term.
So the middle term is always defined as 2n-1?
Yes, if there are n terms in a sequence and n is odd.
No, if there are n terms, for n larger than 1, then 2n- 1 is larger than n! If n is odd, then the middle term is indexed by (n+ 1)/2.
Wow. I need to wake up. I think I meant to say: if the middle term of a sequence is the nth term, then there are 2n - 1 terms in the sequence. :blushing:
1. What is a geometric sequence?
A geometric sequence is a sequence of numbers where each term is found by multiplying the previous term by a constant value. This constant value is known as the common ratio.
2. How can I find the common ratio in a geometric sequence?
To find the common ratio in a geometric sequence, divide any term by the previous term. In the given sequence, the common ratio is 0.256/0.1024 = 0.25.
3. How do I find the value of a specific term in a geometric sequence?
To find the value of a specific term in a geometric sequence, use the formula Tn = T1 * r^(n-1), where Tn is the term you want to find, T1 is the first term, r is the common ratio, and n is the term number. In the given sequence, T3 = 0.1024 * 0.25^(3-1) = 0.1024 * 0.0625 = 0.0064.
4. What is the middle term in a geometric sequence?
The middle term in a geometric sequence is the term that is exactly in the middle of the sequence. In the given sequence, there are 3 terms, so the middle term is the second term, which is 0.256.
5. How can I determine if a sequence is geometric?
To determine if a sequence is geometric, check if each term is found by multiplying the previous term by a constant value. If so, the sequence is geometric. Additionally, you can calculate the common ratio to confirm.
  • General Math
