• Support PF! Buy your school textbooks, materials and every day products Here!
Geometric Series Question
  • Thread starter brojas7
[itex]\sum^{\infty}_{k=4}[/itex] [itex]\frac{1}{5^{k}}[/itex]
ar^n=a/(1-r)
Here is what I did:
a=5
r=1/625
(1/5)/(1-1/625)=(1/5)/(624/625)=625/3120=125/624
The Answer is 1/500
Where am I going wrong?
Answers and Replies
Dick
26,258
618
ar^n=a/(1-r)
Here is what I did:
a=5
r=1/625
The Answer is 1/500
You've got a and r wrong. a is the first term in the series and r is the common ratio. Try again.
Fredrik
Staff Emeritus
407
Can you rewrite the sum in the form
$$\frac{1}{5^4}\sum_{i=0}^\infty(\text{something})_i?$$ This isn't absolutely necessary, but if you do, you can use the version of the formula with a=1.
i meant a to be 1/5...
the first term was 1/625
If I do it that way,r would equal 1/5 right?
$$\frac{1}{5^4}\sum_{i=0}^\infty(\text{(1/5)^n})?$$
Fredrik
Staff Emeritus
407
Yes, assuming that you meant what I hope you meant when you wrote ar^n=a/(1-r), which doesn't really make sense. :smile:
It worked, thank you so much
The sum of an infinite geometric series of the form ##\displaystyle\sum_{n=0}^\infty ar^n=\dfrac{a}{1-r}##, for ##|r|<1##.
Your given series starts off with ##n=4##. Think you can rewrite the series to make it start with ##n=0##?
I didn't know in order for the formula to work I had to make n=0. Thanks
Related Threads on Geometric Series Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
