Homework Help: Geometry problem help
  1. Nov 26, 2007 #1
    Let AD be and altitude of triangle ABC where angle A is 90 degrees.
    Squares BCX1X2, CAY1Y2 and ABZ1Z2 are drawn outwards from the sides.
    Let AX1 meet BY2 in U and AAX2 meet CZ1 in V
    Prove that each of the quadrilaterals ABDU, ACDV and BX1UV is cyclic
    2. Relevant equations
    3. The attempt at a solution
    I'm not sure where to start, but I've been given a clue
    If angle BUA = angle BDA, the ABDU is cyclic
    Let the point where BY2 meets AC be P
    Consider triangles AUP and Y2CP
  3. Dec 13, 2007 #2
    Ouabache
    Welcome to physics forums!! As you may have noticed, this is a great place to discuss ideas and problems you may encounter, in math and science.
    On your problem, I would start by re-reading this post. There are many knowledgable people here, who are willing to steer you towards a successful solution. But first, you need to try to do some work on your problem and show us.
    I recommend drawing the problem out as you've described it. A large drawing is useful, since you should see separation of the lines you draw, more clearly. I would also recommend using a pencil with a good eraser and a straight edge for this part.
    Next, post what you have drawn as an image.
    Can you tell us what a cyclic quadrilateral is?
    (hint: if you cannot find it in your text, look it up on the web).
